Really Poor guys coilover set up
Started by shasharep, April 27, 2003, 04:57:19 PM
shasharep
We are all going for more flex, so lets see if this would work....A ton of companies claim they have a three or four link set up for various rigs that keep the axle where it sould be, noemally but how about this. Take your springs and remove all but the longest one or two leaves and weld in the needed brackets to mount some Kings, Bilstein, Sway-away, coilovers from the axle to a cross member directly above the mount on the axle, set the desired height on the coilovers, and done. I know I have oversimpifitd the equation but I only did it to spark conversation.... Your leafspring will keep your axle whaere it is meant to be... So will it work??? or should I go  :thud:
Late SHAW
37's, detroits, longs, tube doors, stinger, Aw hell just look for a pic.......
#1
seen it done it works but is very frail and gets destroyed rather easily.  but it does work! guess that answers that one huh?
shasharep
#2
yup. I just wonder if it is feasable...
90TOYPU
#3
Think about axle wrap.......BIG time. Links eliminate all wrap.  You would need such good traction bars that you mine as well have made a link system. Way to keep the old thinker working though.
HELLO
