differentials?
Started by Bigbadtoy, May 18, 2005, 09:24:17 PM
Bigbadtoy
ok i have a 91 toy with a 4cylinder i got a rear axel out of a 86 toy with a 4 cylinder will they both be the same gear ratio? the diff out of the 85 was out of an sr5 truck i believe will they work because if it will im making a lincoln locker?
i love playin in the mud
seanc
instructions:
jack both tires off ground
rotate drive-line until tire does 1 revoloution
number of driveline rotations:1 tire revoultion = differential gearing (unimogs need not apply)
You win some, you lose some.
Bigbadtoy
i should be able to tell by the number of teeth on the ring gear right ?
mr4x42u
yup,,,count the ring and pinion and divide...should be the same,,but better check to be sure..I like counting them my self just to be sure.. :beerchug:
check the codes on the firewall/drivers door   if they are the original gears ,  but counting teeth is fool proof
bluetoy84
If they are both factory 4.11's like they should be , you can look at the end of the pinion and it should be painted pink. Toyota painted the end of the pinions as a code for different ratios. 4.11's are pink. That is an easy way to tell without pulling the diff apart to count the teeth.
