Rear-up-front w/chebies
Started by TrailCarnage, May 13, 2005, 05:04:57 PM
TrailCarnage
I am planning to move my rear springs up front. I have done a bunch of research on this but haven't found all of the answers that I am looking for.
1) Can I use both the factory leaf eye and shackle mounting locations? I would like to stay away from dropping the spring eye if possible. I have already rotated my balls. "He sad balls..." :eyebrow:
2) When using the OE shackle mount, do you have to use boomerang shackles ot clear the body mounts? If so, do any of you have a drawing of the boomerangs? I would like to fab them before I take everything apart. This would be greatly appreciated. :biggthumpup:
3) When building the custom pack, do any of you have recommendations for leafs? How many did you use? What applications were they from? How much lift did you get? I have a FJ60 rear leaf pack, 85' P/U rear leaf pack and a '85 P/U front 4.5" Rancho leaf pack to work with. I was considering simply replacing the Rancho main leaf with the factory rear main leaf.
4) Anybody have dimensions for a low-profile spring mount for mounting the Chebies? Once again, I would like to pre-fab it. I also want to loose the lift blocks in the rear. Will I need a AAL to make these go away?
BTW- Up front, I am installing a FJ60 axle with IFS hub bodies and OTT widening kit. The steering is from an FJ60 and modified by "W" out in Washington. In the rear, I am installing a Tacoma axle with Monte Carlo disc brake conversion. I am totally stoked about this! :beerchug:
Any help or advise will be rewarded in the afterlife. Sure, I promise. :greengrin:
oddball
#1.. I think you have to use a drop mount for the rears because they are longer, the stock front spring hanger is inherently weak as sometimes they crack. Balls?
#2..You can trim the cab or use boomerang shackles, remember its recomended to use a xover type steering
#3..check out the rears up front faq on pirate
                                                           Thats all the info I can provide :beer:
1.  You don't have to use a drop hanger.  They will work in the stock location.
2.  You don't need to use boomerang shackles.  I have my front spring eye moved 1 inch back of stock location and my shraight shackles bearly nudge the frame.
3.  I don't know how arched the FJ60 springs are, so my only help for that would trial and error.
