brake rotor quest?>
Started by ozzy93xtra, May 12, 2005, 07:59:08 PM
ozzy93xtra
Sorry for the newbie quest but....when i am driving i can hear a ticking type noise every revolution of the front (also if i hit a bump or on a rough road it is worse) tire and when use my brakes, i gets louder and sounds like it is metal to metal...i just put new pads on last weekend but did not turn the rotors, is that what i need to do? just doesnt seem like that would be the problem.  :dunno: just dont want to take it to a shop and get charged out the a$$
M- I- S- S- I- S- S- I- P- P- I- B- O- U- N- D-
It's probably a broken pad retaining spring or a loose or broken anti squeak plate.  I was hearing a similar noise recently on my 4by, looked at the springs and they were broken.  Autozone had em dirt cheap.
alwayzbroken
The best way to find out is to just take it apart and look.  :hammerhead:  :)
brainlessfool
Northern Runner
Sorry, I just have to ....cannot pass this one up.... :hammer:
Maybe you have a rock stuck in the tread of your tire....
:greengrin:
ozzy93xtra
found it... the pin that hold the shoes in place fell off and the pins had worked their way loose and were rubbing against? so i knocked em back in and "afro engineered" some new pins thanks for your help though :thumbs: this board is the best :beerchug:  :beer:  :beerchug:
Northern Runner
Ain't it grand when it's a easy fix...
Usually its an entire weekend to find the gremlin..
