ifs diff
Started by mudaddict, May 10, 2005, 11:11:59 PM
mudaddict
Alright so i am woundering how hard it is to remove a ifs diff. i will be going to do this soon. so any help will be much appreciated. any tips on what to do or how to do somethign would help. i will be installing a locker so i need to get to the whole thirdmember and i am not sure on what needs to be done to get there because i ahve not pulled it before.
I work At
All Pro Off Road
Why waste the $$ on a locker for ifs?  You are going to break cv axles on a very regular basis....
Mike D
Kurtis I'm gonna  :smack: you
IFS :slap:
mudaddict
because my sas will not be done for about 2 years  :dunno:  dont ahve the money to do anyhting else i will be locking the rear very soon.
I work At
All Pro Off Road
mudaddict
thats what cv axles with lifetime warranties are for :yupyup:
I work At
All Pro Off Road
86 4runner
its abitch changing them and i would hate to do it all the time. a life time warrenty doesnt do you any good on the trail
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
Weld the rear and save you $$ for a sas later.  You'll thank me later. ;)
mudaddict
i ahve 2 years in arizona to save up that is going to be the first thing im going to do is an sas when i get home. my dad will not allow me to do the sas until i get back :down:
I work At
All Pro Off Road
BLACKDOG
mudaddict, it isnt hard to drop the whole third.  As for being locked, I am locked in the front, and I have yet to break a CV :psss: but I am picking up spares anyway :yupyup:
I found it easiest to use ramps for this, if nothing else it gives you better work angles.  IT is nice to have a buddy helpyou, but you dont need another person.
1. unbolt driveshaft, zip tie it up out of the way (along the torsion bar is good)
2. unbolt the CV axles from both sides.  (leave that front bolt in for now, it helps prevent twisting of the entire third)  To get the CVs, I didnt have air tools, so I had to lock the hubs, and break loose two or three bolts, then unock the hubs, spin the axle, and lock the hubs again.  There are 6 bolts on either axle
3. after both CVs are off the third, get a floor jack or jackstand and start unbolting the third from the frame.  there are 3 bolts i think on top of the third on the pass side, 2 on the drivers side, and the bolt that goes through the diff. cover.  To get the third out, you might have to take off the diff cover, i did when i took my old third out, and it was a PITA to put the new diff in with the cover on.  your preference.
4.  lower the jackstand or floor jack until the third is sitting on the IFS frame assembly.  get out of the way, make sure your legs are out of the way, and push the third through the frame and let it fall.  It wont hurt the third, and it is a huge hassle to lower it and move it using a floor jack or something like that.  You can even lower te truck back down of the jackstands or ramps so the third doesnt have as far to fall.  if you take the dif plate off, make sure you dont let it fall on the ring gear.  :psss: dont do do this on cvoncrete unless you put cardboard or plywood down first, you can break the concrete when the third falls.  If you need anymore help, let me know.
:psss: If you are going with a locker and 5.29s, I may have an available IFS diff this summer, already setup :thumbs:
              -Ronald Reagan
gonzo
Quote from: WHITE_TRASH on May 10, 2005, 11:39:42 PM
Hey mudaddict. is this your daily driver?
I have dd'd trucks with welded rear ends for years with no issues at all.  Id rather have a welded 3rd or a spool in the rear over ANY auto locker any day of the week.  ;)
BLACKDOG
Quote from: WHITE_TRASH on May 11, 2005, 11:26:25 AM
Thats what I'm gonna do when I go SA. weld rear, dunno what locker up front.
              -Ronald Reagan
mudaddict
thanks blackdog, hey wt im gonna follow the wise advice and weld the rear! im not sure how to do it or anyhitng so looking for some help. i could amke a trip over and you could help me or something. my sister lives not to far form your house so i cam visit her too. ya i already have the locker for the front its on its way here as we speak.
I work At
All Pro Off Road
The rear is uber easy to weld up.  PM To the floor or skinny pedal.  One of them should still have the 3rd that I welded up so you can see how its done.
mr4x42u
agreed,,don't lock the front,,you will have fun with just the rear locked and an open front,,with less front broken parts..
HFCRAOffroading
#15
I will have a IFS Diff for sale in a couple of weeks with 4.10's and an EZ Locker already installed.  If you want it shoot me a PM and we can work something out.
I ran it in my 91 Toyota for about 3-4 years and never broke a front axle.
grandeyota
The studs that hold the CV axles in are a pain. Pound them out and either grind off the ribs so they are just like bolts or use some grade 8 bolts in thier place. Makes all the difference in the world for next time. I've not had too many problems with CV axles as far as breakage, mostly torn boots are my problem. But I only run in the mud, no rocks or anything like that where I am so it's a different kind of stress on them.
When taking the CVs out, try using a jack under the A-arm and try playing with the angle a bit, it gives you a little more room. Oh and strip any paint off the diff cover and polish the snot out of it for some :bling:  :talkingn:
The skies are always sunny in the heart of flavor country
mudaddict
thanks for the help guys i will probly be install this after i graduate because then i can stay in the shop all day and do this and not have to worry about school and time.
I work At
All Pro Off Road
