3.0 overbore
Started by Oreo, May 13, 2003, 02:05:07 PM
Oreo
I am going to get my 3.0 rebuilt in my 4runner and figured I should get the cylinders overbored at the same time. Has anyone had experience with overboring their cylinders in a Toyota 3.0 v6? How much does it cost and where is a good place to get it done? Any info would be great.
Incapable Front Suspension
#1
Are you refering to a standard 20 or 40 over or are you looking for a maximum bore?
mr4x42u
#2
also remember you will get more power out of the engine from head improvements over bore..bore only does as mush good as the head lets in or out x amount of air and fuel through..so just bore is not always the awnser..
84runner
#3
The average price is about $10 a hole give or take
Oreo
#4
I'll probably go maximum bore. I will be getting ported and polished performance heads from D.O.A. Do you guys know where I can find a rebuild kit (other than D.O.A.) that comes with pistons/rings/crank  made for an overbored 3.0? Also how much?
mr4x42u
#5
I would check L C but would not go with anyone other then those L c,doa,or trd if available..
Remotruker
#6
LC does not do anything v6 as far as i have ever seen....
Remotruker.tripod.com
Check it OUT!!!!!
#7
D.O.A.   is the only way for performance 3.0
althouhg i wouldn't do it , i would swap in a 3.4  :chug:
