W56C popping out of all gears
Started by toyhatsu, April 27, 2005, 04:51:07 PM
toyhatsu
I bought the W56c from a salvage yard about seven months ago for my build up.  I just now got the clutch working and it is popping out of all gears.  I bought a new Marlin shifter seat and socket because I knew that it was popping out of first and hoped that this would help.  Would new detent springs solve this?
Thanks
1991 Daihatsu Rocky, 3RZ-fe, Marlin super heavey duty clutch and pressure plate, Marlin W56-C-HD, duals, Marlin twinstick, three link front with Fox AirShox, 35's, Toy axles, 5.29:1, ARB F&R etc.
Uncle Jesse
It's possible that new detent springs could fix it, but could all of them be bad at once?  Do you have a shifter boot on there?  See if the boot doesn't have enough movement and is making tension on the shifter, sliding it out of gear.
toyhatsu
No I haven't got around to putting boots on.  Just swapped out the rail and fork in the front xfer case as it was for a G52 and I needed the shorter W56.  I put new detent springs, balls and caps in it.
