Author Topic: toyota front axle widening kit  (Read 6111 times)
marleyoffroad
  • Male Posts: 115
  • Member since Dec '04
« on: Apr 27, 2005, 04:42:10 AM »
is anyone running one of these? or does anyone know the pro and cons of it?
which one is better marlin wheel spacers or this kit? i am looking at safety.......
95 toy,marlin sas,5.29aussie locker(f)/5.29detriot(r),30 spline longs/4140 superior axle (r),custom 6" alcan spring(f),dual triangulated 4link(r),hysteer,68"diamond axles,bilstein 7100s at all 4 corners, duel ultimate,fror x-member,
raybie
  • Turtle Points: 423
  • Member since Jul '03
Re: toyota front axle widening kit
« Reply #1 on: Apr 27, 2005, 08:40:48 AM »
there was a big debat on pirate4x4 a while ago.  i'm running the sky's kit and like it.  one thing i like is that the spacer only sees braking loads where a wheel spacer would see braking, acceleration, turning, and side load forces.  so i feel better that they see less loads.  but there are advantages to the wheel spacers, cheaper and quicker to install and you don't have to have ifs hubsl.  the sky kit was a bit of a pain in the arss to install.  we had trouble lining up the spacer when pressing it on to the hub the first time.  the second one i made a guide pin out of a bolt with the head cut off and then made sure to pollished all the rust and crap off the surface of the hub where the spacer presses on, used a bit of white grease and it went right together.  the one thing i don't like it that you would have to press the rotor off to replace it... not a big deal as i don't plan on haveing to change rotors all that often.
WHITE_TRASH
  • Turtle Points: 679
  • Member since Feb '03
« Reply #2 on: Apr 28, 2005, 01:08:01 AM »
I have been running Karmirtoy's setup for about a year with no issues whatsoever.   Heres the link.
http://www.pirate4x4.com/forum/showthread.php?t=245396&highlight=Kamirtoy
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
« Reply #3 on: Apr 28, 2005, 01:35:38 AM »
yea,,thats the best set up i have seen..
marleyoffroad [OP]
  • Male Posts: 115
« Reply #4 on: Apr 28, 2005, 05:51:16 AM »
thanks WT that looks like a solid set up ill have to look into this when i get a chance.
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #5 on: Apr 28, 2005, 07:56:39 AM »
I will be making my own set before the Rubithon (in two months).
I plan on using the wider IFS parts + a 1.5" wheel spacer + 2" offset wheels. I gotta go as wide as possible.
If I start having problems them I'll have no choice but to go full width Toy axles (FJ80 front, Taco rear).
WHITE_TRASH
« Reply #6 on: Apr 28, 2005, 01:08:42 PM »
Holy crap Mikey your scrub radius is going to be insane!  Why the heck do you want to go that wide?
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
« Reply #7 on: Apr 28, 2005, 01:20:12 PM »
I have sky's widening kit and plan on putting wheels spacers on in addition. I bought the wheel spacers before I bought the sky kit so I might as well use 'em. I can always take off the wheel spacers. The sky kit looks like a good product except they are too lazy to give you the proper sized dowel pins so you have to drill out the rotor to fit the oversized dowels. Which is not bad but leaves room for error if you don't have a drill press or a steady hand.
83yota
  • Turtle Points: 372
  • Member since Mar '04
  • rollin my nike's
« Reply #8 on: Apr 28, 2005, 03:51:21 PM »
that is what i call WIDE track
88runner
  • Turtle Points: 756
  • Member since May '03
  • Click me!
« Reply #9 on: Apr 28, 2005, 04:19:26 PM »
here's my setup, home made spacer ifs rotor,caliper,hub. You loose 1/4" of contact space on the rotor since it's smaller then the fj40 rotor but for what I could have only 1 fj40 rotor, I had the spacesr made, new rotors and new pads. So who care about 1/4", I have rear disk brake!!
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
86yota
  • Guest
  • Marlin Crawler
  • I used to Crawl. I still do, but I used to, too.
« Reply #10 on: Apr 28, 2005, 06:36:40 PM »
Now thats the setup im familiar with.  A local 4x shop here has these spacer kits for about $100.  Using IFS rotors and calipers.  Good kit!
Last post Dec 08, 2002, 05:57:34 AM
by tonka
Last post Jan 15, 2005, 05:11:54 PM
by bkg
Last post Dec 24, 2008, 05:58:45 PM
by 79coyotefrg
Last post Aug 28, 2013, 10:23:06 PM
by THK Matt
Last post Dec 15, 2010, 01:44:19 PM
by SFD4x4
