My 83sr5 shortbed
Started by Ramrod, April 26, 2005, 10:47:15 AM
Ramrod
Here are some pictures of my truck. I have not done anything new to it in a while but here are some pictures of what I have done so far.
Here is how I got it in late october from 92krawler from the pirate4x4 board.
Ramrod
Then I did a rattlecan paint job bobbed the bed twelve inches. Put some lift shackles in the front and I was here
Ramrod
then I was ready to really start tearing into it.  Here it is 1 minute before making it what it is now.  I did all the work in 4 days by myself. It is 2" drop hanger in front plus 2" lift shackles with rears up front and skys highsteer. 5:29 gears and open diff. ford shock towers and 14" travel procomp es9000 all adding up to 5" of lift.
In the rear is 3 leaf chevies with no overload and 2.5" blocks and dual shackles and 15" travel procomp shocks with mounted like/\adding up to 4 inches of lift
Ramrod
so here it is now since then I have put an aussie locker in the rear and made a square drive shaft for the front and wheeled it pretty hard. I am hopefully buying a new rearend with a detroit in it so I can put the aussie up front and have my marlin dual case adapter in the mail and should be here today.
Ramrod
So the adapter came in yesterday. It was a breeze to put together.  Whoever made those directions is the man!! It only took about an hour and a half to take apart my extra transfer case and reasemble it with the adapter.  I will not be able to install it in my truck till sunday because my truck is my dd and I will need to have the the driveshaft shortend.  But here are some pictures of it assembled anyways.
Ramrod
Well my dual cases are in as of yesterday.  That was a very easy install.  Now I just have to sit around all day today waiting for my driveshaft to get redone.  But here is some pics from yesterday.
Ramrod
I also went a picked up a complete rearend with 17,000 miles on everything new including this for $175 My question now is what type of birfield/inner axle setup should I use when I put this up front.  If I send my birfs to longfield to get heat treated will that be enough with 36" tires or should I just save up and get his 27 spline super set with the inner axles.
yotapride
how do you like that assie locker??
Ramrod
I love the aussie I cant decide if I want to put it in front and put the detroit in back for more strength or keep the aussie in the back because it is so smooth.
BLACKDOG
Quote from: bigbluewillys on May 06, 2005, 02:13:03 PM
put your detroit in the back and the aussie in the front, you wont regret it :nope:  I've got a detroit in the rear and a lockrite in the front, and it works out really well
              -Ronald Reagan
Ramrod
Yea I was kind of leaning that way any ways and I think I am going to.  What are your recomendations for my birfields on a budget I know I will definetly need something.
BLACKDOG
as far as birfs go, I am in the same boat you are.  I havent done my SAS yet, so I am not sure.  I would assume the stronger the better, so if you've got the means, go with the beef
              -Ronald Reagan
