Mini Spool
Started by whiteman, April 21, 2005, 03:39:01 PM
whiteman
 :help:    I cant find any Mini Spools for a Toyota rear axle!  It is behind a 86' 4-runner with 22re.  Do they even make them? Where can I find one?
Rockdiver
Marlin has a full spool for sale I believe
whiteman
I am looking for a mini spool that way I dont have to reset my geras.
notajeep
gears arn't really an issue in a toyota if you are not removing the pinion gear.  The ring gear only has about 4 adjustments.  There are no shims to deal with on the ring gear with a toyota.  You can do it!  :thumbs:   Or weld it, I'm sure that there are plenty on this board who would offer advise on how to do it properly. :psss:
Ramrod
on a toyota rearend you will have still have to reset your gears if you do a mini spool because you will have to take the carrier out anyways to take of the ring gear so you can drive out the center pin deal and then take out the spider gears.It would probably be easier to put a spool in with some new bearings and even easier yet you could just weld it and get the same result.
Jack8542
Quote from: bigbluewillys on April 21, 2005, 07:39:02 PM
I agree, welding a diff gives you the same result as a spool and doesnt cost a dime if you have access to a welder.   :turtle:  :usa:
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
86yota
Spool it.  Like Notajeep said.  Just set backlash and go.
