Dom, welcome, you could put a Lower gear transmission in. while these are 4wd types I am sure a 2wd model could be assembled. As usual Marlin will have to give that final answer....<snip>We can rebuild the entire gear set with an imported gear set. New gear ratios: 1st 5.15, 2nd 2.74, 3rd 1.93, 4th 1.00 5th .83 Reverse 4.23 First gear ratio is 34% lower than the stock ratio (5.15 vs. 3.83). Cost $650.
I would think you need a transmission from a 4wd Toyota to bolt a reduction case on there. The output shaft is too long on the 2wd. (at least this has been found true on the auto transmissions)Then you would need some sort of output housing to go in place of the transfer case. (never seen anything like this)The easiest, somewhat bolt-in, off the shelf answer I can think of would be swap in transmission and transfer case from a 4wd truck. Not perfect, not space effecient but good excuse to go 4wd!URI......hmmmmm......looks cool!
Anyway - as far as output shafts being too long: we've got some pretty clever transmission people in Windhoek, and they can probably modify the output shaft easily enough.What might work is to use the 4wd version of the G52, and stick a reduction box on there...Anyway: thanks all for the suggestions; keep 'em coming!
Oh ok, I was thinking easy and cheap. The 4wd G52 + reduction box + machined billet adapter for reduction box to tailhousing or all new billet tail housing that bolts directly to the reduction box. Guess you would need a short output shaft made too.Doesn't sound so bad if ya say it real fast.
:slap:he has 4.88's :psss:and 7.50 16's
Got wheelbase?
Is that a bad thing? 7.50s are 32" tall when all is said and done, which is taller than some 33s...and 7.50s will withstand abuse like no other tyre.What about my 105? approach and 45? departure angles? The 40:60 front/rear weight distribution? The 1200kg fuelled kerb weight? The 45 centimetres of front ground clearance under the sump?Toyota 4wd sprung-over rear axle, Namibian engineered front crossover independent suspension (made of rebar).The vehicle is more or less stock from the factory this way...Anyway: yeah; Glen's suggestion amounting to 88:1 is pretty appealing. So, Marlin people; can it be done?
good thing I am not a carpenter or have to measure for a living
Started by toyotaboy « 1 2 » Parts For Sale
Started by 51504ROCK RC Rock Crawler Tech
Started by Gearhead Wiki Chit Chat Camp
Started by yota18 Project Research and Build-Ups
Started by 85yodaon33s Chit Chat Camp
