DIFFTOBER Returns: Our Biggest Differential Sale of the Year!
Started by Marlin Crawler, September 28, 2025, 09:07:02 AM
Marlin Crawler
Creep into our bone-chilling Specials!
13% off all Built Differentials
Summon 13% off and unleash the crawl of the undead!
Choose from ARB, Grizzly, Spartan, Spool, Truetrac, or Zip-equipped Locked or Open Differentials ranging from 1958 to 2024 Toyota & Lexus applications, on our long-lasting Fully Built & Guaranteed Differentials!
13% off all R&P Gear Sets
Carve 13% away and let it vanish into the mist!
From 7.5" to 10.5" differential options for Toyota, Land Cruiser, and Lexus
10% off all Diff Builder Packs
Snatch 10% before the midnight spirits take it back!
The Perfect DIY Package with everything needed to upgrade your Diffs
10% off all Setup Kits
Bury 10% in the graveyard of broken parts!
High Quality Yukon and Revolution Gear Kits
13% off all Axle-related Service Kits
Drain 13% under the full moon with our Japanese-sourced service kits!
Knuckle Rebuild, Gasket Kits, F&R Wheel Bearing Kits and Seals
13% off Front & Rear Chromoly Axles
Scare away 13% on 27- and 30-spline Front Solid Axle Chromoly Axles, IFS Ultimate Stock Length/+2.00"/+2.75"/+3.50" Axle Sets, and Rear Chromoly Axles!
13% off all LCA Frame Brace Kits
Slash 13% and let the ghouls guard your frame!
The ULTIMATE end-all solution that goes far beyond only just your Cam Tabs
13% off all Axle Armor and Gussets
Scare 13% away and armor up against the creatures of the night!
Full Face Diff Armor, Backing Plate Eliminator, Axle Reinforcement Gussets, Knuckle Gussets, and E-Locker Motor Guards
10% off all Air System Products
Wave your wand and make 10% vanish into thin air!
ARB Air Compressors, Power Tank Systems, Seamless Alunimum Air Tanks, and Speed Flate Kits
10% off Service & Installation
And finally, 10% off all Service, Installation, and YotaWerx ECU tuning jobs done locally here in Fresno by industry-leading trusted technicians trained by Marlin himself!!
Call or Click Here for inquires and to get scheduled on our calendar today!
View full Sale Online at
MarlinCrawler.com/DIFFTOBER
Thank you for saving with us this October!
Check out our 10% off 250th Anniversary Sale – LIVE NOW!
Private Messages are not monitored
Please contact us at MarlinCrawler.com/contact or (559) 25-CRAWL / 559-252-7295
Marlin Crawler
Our Largest Differential & Axle sale is down to the FINAL WEEK!
Save 10% to 13% on over 250 products as well as 10% off on all Installation, Rear Gear, & Service Labor while time lasts
  • 13% off Built Differentials
  • 13% off R&P Gear Sets
  • 10% off DIY Builder Packs
  • 10% off Setup Kits
  • 13% off F&R Axle Service Kits
  • 13% off F&R Chromoly Axles
  • 13% off LCA Frame Brace Kits
  • 13% off Differential Armor
  • 10% off Air Systems & Tanks
  • 10% off Service & Installation
Click to view sale: MarlinCrawler.com/DIFFTOBER
Also, we forgot to post earlier that at mid-month we placed All LOCKERS on sale at 10% OFF!
Selectable Lockers: Zip & ARB Air Lockers
Automatic Lockers: Grizzly & Spartan Lockers
Limited-slip Locker: Dura Grip Locker
Always Locked: Spool Locker
View them all at MarlinCrawler.com/products/differential/lockers
Marlin Crawler
🎃 DIFFTOBER LIVES ON! 🎃
You thought it was over... but the deals have risen from the grave!
Our 16th Annual DIFFTOBER Sale has been extended through TONIGHT, giving you one last haunting chance to save 10–13% on more than 250 Differential & Axle products!
Carve out your savings before midnight strikes:
🕸 13% off Built Differentials & R&P Gear Sets
🕸 10% off Lockers (ARB • Zip • Grizzly • Spartan • Dura Grip • Spool)
🕸 13% off Chromoly Axles, Service Kits, Armor & Frame Braces
🕸 10% off Air Systems, Setup Kits, and Service & Installation
Don't let these spooky savings vanish into the mist. When the clock hits midnight Sunday, the spirits will seal the vault!
