Marlin Crawler RCLT HD – Proven Heavy Duty IFS & Steering Performance
Started by BigMike, August 22, 2025, 02:28:59 PM
Hello Crawler Land!
It's been a while since I last posted on this and with many updates to RCLT HD I thought it was time for a fresh thread dedicated to info, tech, and FAQs. Our original thread from 2019 captured the early days, but we've come a long way since then. Today, RCLT HD has matured into a proven, heavy-duty system built for drivers who want reliability no matter how far from civilization they travel.
What is RCLT HD?
RCLT HD is the first replacement IFS suspension + steering system built strong enough for rock crawling, which is the harshest proving ground for any suspension and steering setup. It's been tested for years on trails and in Ultra4 competitions like King of the Hammers, with eight consecutive competitions without a single IFS or steering failure.
And because it's proven in rock crawling, it's equally at home on every other use case — from overlanding trips and backcountry exploration to weekend trail rides and even daily driving. If it can thrive under the punishment of rock crawling, it can deliver confidence and reliability for any driver, anywhere.
RCLT HD is designed to solve problems every IFS driver knows too well: weak steering racks, fragile knuckles, poor ground clearance, and limited tire fitment options. With RCLT HD, those compromises are gone.
Features at a glance
  • Heavy-duty, more powerful MarRack steering – replacement steering rack engineered to handle harshest of trails yet comfortable for daily driving. Billet steering arms and 5/8" double-shear tie rod ends have racked up over 100K+ miles on 40" tires with zero failures.
  • All-new lift-specific geometry – restores alignment and handling for smoother on-road manners and predictable off-road control not found in other lifted setups reusing stock knuckles
  • Patented forward-offset geometry – fit larger tires with less effort than any other setup (up to 38s with no body mount chop or relocation)
  • Massive double-shear billet steel knuckles – CNC-machined and built to survive the hardest off-roading, ensuring strength and reliability in every scenario.
  • Unmatched Articulation – Up to 14" at the hub from only a +2.75" mid-travel design.
  • Strength Everywhere – Double-shear ball joints, reinforced frame mounts, 1/4" internal gusseting
  • Industry-leading ground clearance – equally valuable on the rocks or on fire roads loaded with gear.
  • Industry-leading approach angle – protect bumpers, winches, and accessories whether climbing ledges or weaving forest tracks.
  • Integration – Retains ABS, cruise, traction control. Mostly bolt-on with detailed instructions. Transferable between compatible 2003–2024 Toyota/Lexus platforms.
Proven in the Real World
On my own Tacoma running 40s, I've clipped rocks hard enough to whip the wheel out of my hand and stall the engine. Each time, I expected carnage, even my air bags to go off. But my steering wheel never went out of alignment and my truck tracked true back on the highway. After years of testing, I don't even carry spare steering parts anymore. That's the kind of confidence I built RCLT HD to deliver.
Value Comparison
Most long-travel kits still rely on stock racks, gusseted knuckles, and tie rod upgrades, which are all weak links that add up fast. By the time you patch those gaps, you've spent $8K–$9K and are still left with many compromises.
With RCLT HD you get the only fully-integrated heavy-duty IFS + steering solution:
  • Heavy Duty MarRack steering
  • Billet knuckles & heavy duty control arms built for abuse
  • All-new geometry engineered for lifted applications
  • Proven performance in Ultra4, KOH, and countless on-road and trail miles
This isn't about throwing more money at bandaids, it's about investing once in a system designed to eliminate failure points for good.
In Closing
RCLT HD was born from rock crawling, the most punishing environment an IFS system will ever face, and we've spent years pushing IFS further than anyone thought possible. That means whether you're picking through granite ledges, running loaded overland trips deep into the backcountry, or just wanting your daily driver to be free from weak links, this system is built to last the life of your vehicle.
With RCLT HD, you invest once in a suspension and steering system that eliminates the compromises of stock IFS. No more bent knuckles, broken steering, or patchwork fixes — just reliable strength, predictable handling, and confidence every time you turn the wheel.
Click here to learn more: marlincrawler.com/products/suspension/rclt
I plan to share more in-depth info below so for all my fellow tech junkies stay tuned
Post up your questions below, and for current RCLT HD owners, share your rigs and trail shots!
Regards,
News & Engineering Proof
RCLT HD becomes the first-ever IFS Toyota to complete both laps of the brutal 165-mile KOH race! Click to read our blog post
Trail Pics & Customer Rigs
November 50/50
The RCLT HD + MarRack Deal Returns
In August, we tried something new: For a limited time, every RCLT HD kit included a brand-new Toyota Land Cruiser steering rack.
The response was incredible. Many of you told us how much you appreciated a complete, factory-quality system, all engineered and packaged together.
So for the month of November, we're bringing it back, this time with a twist:
Get 50% off a Genuine Toyota 200-Series Land Cruiser steering rack with every RCLT HD kit.
That's a savings of over $500 on the same steering rack we trust in every in-house build, including our own RCLT HD-equipped rigs.
Why We Only Trust Genuine Toyota Racks
Your steering isn't just another component — it's the lifeline between you, your tires, and the terrain ahead.
That's why every RCLT HD system uses 100% Genuine Toyota 200-Series Land Cruiser racks, manufactured in Japan by JTEKT, Toyota's steering supplier for over half a century.
Could we use cheaper alternatives? Sure. They're out there, and they look the same from the outside.
But inside, the differences are huge: lower-grade metals, looser tolerances, and seals that fail under pressure.
When you're running oversized tires or tackling technical terrain, that's not a place to compromise.
My own MarRack has logged over 70,000 hard miles on 40" tires and still has zero play, zero leaks, zero issues.
That's why we'll never settle for anything less than OEM Toyota quality.
Offer Details
✅ 50% off Genuine Toyota Steering Rack with any RCLT HD kit
✅ Available through November 30 only
✅ 99% bolt-on, patent-protected design
✅ Limited monthly supply from Japan
We build products the way we want them on our own trucks — tested, proven, and never compromised.
Because when you're driving a 6,000-lb rig on the edge of traction, precision isn't a luxury, it's peace of mind.
Invented here. Perfected since 2018.
Limited Time Offer: RCLT HD × YotaWerx Tuning
November 1 – 15 Only
YotaWerx Tuning has teamed up with us to bring RCLT HD owners an exclusive engine upgrade at 50% off.
No matter what trails you run, a YotaWerx tune perfectly complements your RCLT HD system: smoother throttle, improved torque, and optimized drivability for larger tires and gears.
The Details
⚙️ 50% off any YotaWerx tune when purchasing RCLT HD
⚙️ 50% off for existing RCLT HD owners, too! (through any authorized tuner nation-wide)
⚙️ Available Nov 1 – 15 only
Because great builds deserve great partnerships: Stronger suspension, smarter power.
View ECU Tunes
Two legendary upgrades, One goal: Performance done the right way.
Steering Geometry That Works — and Why It Matters
Originally posted to the bottom of our Genuine LC200 Steering Rack Product Page
"It drives like a Camry" — Nate Pickle
When we first began adapting the 200-series Land Cruiser steering rack for mid-size Toyota platforms back in 2018, it wasn't just about strength, it was about control.
The challenge was clear: The Land Cruiser rack is significantly wider than any mid-size Toyota frame was ever designed for. Simply bolting one in throws off steering geometry, increases bump-steer, and introduces serious handling instability. We know, we tried it firsthand in 2018 and nearly lost control on the highway. That's when we decided that if this swap was ever going to be done safely, it needed to be done right.
So we spent two years engineering, testing, and patenting a geometry-correct system that integrates the oversized Land Cruiser rack with entirely new knuckles, steering arms, and control arm geometry. The result became the foundation of RCLT HD — the first and only long-travel IFS kit that fully incorporates a heavy-duty rack designed for a larger vehicle, while maintaining proper mid-size driving dynamics.
How Stable Is It?
Our +2.75" RCLT HD system delivers up to 14 inches of hub travel with only 0.5° of combined camber and toe change through 90% of flex.
That's an exceptional metric in the world of independent suspension, and it's one of the reasons RCLT HD tracks straight, corners predictably, and feels factory-smooth even on 40" tires.
Why It Works
Because we replace both steering rack and knuckles, RCLT HD resets the tie-rod, steering arm, and ball-joint geometry to maintain proper alignment and steering response across the full range of motion.
Moreover, since all of our customers lift their trucks to clear larger tires, we designed our geometry from that lifted baseline, not stock height. Kits that reuse factory knuckles can never truly recover proper geometry once the truck is lifted, but RCLT HD delivers correct alignment and steering response at the ride height enthusiasts actually desire.
It's a carefully balanced system — wider steering arms, optimized Ackermann, and adjusted vertical ball-joint separation — all designed to keep the steering ratio predictable and eliminate bump-steer without forcing customers into oversized 18"+ wheels.
In other words: It's geometry that's engineered, not guessed.
QuoteTL;DR: The 200-series Land Cruiser rack only fails when forced into stock geometry — RCLT HD is the first system engineered around it.
The Danger of "Bolt-In" Rack Swaps
After we pioneered the use of the Land Cruiser steering rack in mid-size platforms, others have experimented by simply throwing the rack in, sometimes in conjunction with other long-travel systems. On paper, it sounds simple. In practice, the result is poor return-to-center, uneven tire wear, and noticeable bump-steer resulting in unpredictable and dangerous driving characteristics.
IFS geometry isn't something that can be "close enough." The relationship between rack width, control-arm pivots, steering arms, and tie-rod length determines everything about how a vehicle drives and feels and it's the reason RCLT HD required full suspension & steering geometry redesign with patent protection.
Some say the Land Cruiser rack can't be used safely or that it delivers poor steering feel in mid-size platforms. But, those problems only appear when the larger rack is forced into stock geometry it was never meant for. RCLT HD is the only near bolt-on full-suspension replacement that correctly integrates the oversized rack, delivering precise steering and confident handling across its full range of motion.
Watch RCLT HD's Stable Geometry cycle with no noticeable bump-steer, toe, or camber angle change, despite using this oversized Land Cruiser steering rack
Real-World Results
Customers repeatedly tell us that their RCLT HD build feels tighter, more responsive, and easier to drive than any lifted or long-travel setup they've owned. Even after years of abuse, their steering precision remains consistent because our geometry is right.
When we say RCLT HD offers "rock crawler strength with factory-smooth steering," it isn't marketing. It's math, metal, and miles of testing.
"I've wheel'd a lot of rigs and my Tacoma on 38" tires is the only Rock Crawler I've ever built that drives like a Camry" — Nate Pickle
"Accomplished Deer Valley trail. Very good handling on the rocks, I was impressed, it's just a different vehicle." —Stanislav Egorov
"Wrapped up the RCLT HD install with an alignment. She drives wonderfully with the 5.29s, supercharger, and 37s." — Chris Gonzalez
"Despite my rig's added weight and 38" tires, steering power, response, and feel has never let me down." — Jeff Kongpachit
"I unintentionally crash-tested my RCLT kit last week.
Solo night driving in the desert, going faster than I should've been.
Blew through the Radflo bump threads.
Phone kicked into emergency mode and started calling 911.
A week later, my wrists and back are still sore - it was that violent of a hit.
Any other setup would have folded.
But the RCLT kit and my rack absorbed everything. I literally drove away with zero mechanical issues.
I shouldn't have walked away from that one - and my 4Runner definitely shouldn't have.
RCLT took the hit and kept me moving. Nothing else compares." — Oleg Flaksman
"Love the reliability! Take the hard lines, air up, and hit the highway home at 80 MPH" — Russell Wright
"I've broken a lot of things running 40s on this rig, but the RCLT has held strong." — Hunter Gill
"What I love about this next generation of my build with RCLT and 37's is the true off-road capability of it and can still comfortably drive 70+ down the highway. I daily drive this rig, easily navigate Elephant Hill in Utah, and road trip it from Washington to the remote areas of Death Valley. It has truly evolved my rig into an ultra capable adventure rig." — Chad Wicklund
"Love my RCLT kit! It's a beast on the trail but still comfortable and reliable enough to daily drive and take longer drives to events." — Shannon Murphy
And from myself if I may: "My Tacoma came with light, frail front-end parts, all of which are now replaced by RCLT HD. I wish every driver could experience this level of peace of mind and vehicle safety both on and off-road. It's how Toyota should have done it." — BigMike, RCLT HD Designer
a1gemmel
Alright that is absolutely too funny given the circumstances
1981 Pickup - 35s, 5.29s, W56, dual ultimate, e-locker front, grizzly rear, 22R stroker, 3 linked on airbags
Quote from: a1gemmel on November 17, 2025, 06:59:04 AM> "It drives like a Camry" — Nate Pickle
:yupyup: Regarding his wife crashing his Tacoma? That is true, but I'd argue how sweet it is that he has an IFS rig running portals with RCLT HD control arms and our MarRack HD steering rack + HD steering geometry and yet his wife is able to drive his rig despite it running 42" tires on IFS.
Keep in mind, before RCLT HD, IFS setups regularly failed even with just 285s (33").
I've driven SAS'd 3-linked Tacomas and 4Runners from 38" to 42" tires and I would never let my wife drive any of those!! Also, alignment shops won't touch them due to liability. But my Tacoma with RCLT HD and 40s, even my grandma could drive it, that's how much "like stock" RCLT HD drives despite having the strength and capacity for much larger than stock tires and far greater articulation for off-road use.
Also, what's great to know for me as an engineer, is that she managed to shear in half a Ford F-250 Super Duty Dana 60 8-lug spindle, and with the added weight and force of 42" tires (probably 165 pounds wheel+tire), knuckles that weigh over 60 pounds each, and yet our upper and lower RCLT HD control arms with their strategically placed 1/4" inner full-length bracing did not bend. Also, the lower control arm frame mounts, gusseted with our Heavy Duty LCA Frame Brace Kit, zero damage to the IFS frame mounts, even despite him running our longest +3.50" kit, whereby the forces at the frame are the highest of all we offer.
Great to see real world tests verifying the strength of our design, but sorry Nate's wife had to go through all that! Glad they are all safe :beerchug:
True testament to the strength and durability of RCLT HD. :hattip:
Regards,
From time to time we receive questions about why RCLT HD uses a 200-series Land Cruiser steering rack instead of a Tundra rack, as well as from customers considering a custom narrowed Tundra rack conversion as an alternative to RCLT HD.
Because of this, we put together the following blog article to clearly explain the differences between these approaches, including what is actually involved in narrowing a Tundra rack, what it really costs once labor and long-term serviceability are considered, and why that route ultimately ends up costing significantly more while delivering far fewer benefits than a true full-size steering system engineered from the ground up.
Why a Narrowed Tundra Rack Isn't the Steering Upgrade It Appears to Be
Post URL: https://www.marlincrawler.com/why-a-narrowed-tundra-rack-isnt-the-steering-upgrade-it-appears-to-be
⚠ Before You Spend Thousands on a Custom Narrowed Tundra Rack
Shoppers considering steering upgrades for lifted, large-tire Toyota/Lexus IFS platforms are often pointed toward a custom narrowed 2nd-gen Tundra steering rack as a way to "band-aid" growing steering loads.
While this approach can appear attractive on the surface, it's important to understand what is actually involved, what it truly costs, and what limitations remain after installation.
TL;DR
By the time a narrowed Tundra rack is machined, installed, and lived with, it costs more, delivers fewer benefits, and is harder to service than upgrading to a true full-size steering system designed for the superior Land Cruiser rack.
What a Narrowed Tundra Rack Conversion Actually Requires
To fit a full-size Tundra rack into a mid-size chassis, a specialty shop must:
  • Replace original full-size rack bushings with offset adapters to fit smaller mid-size hardware
  • Cut the heat-treated inner rack ends to remove full-size inner tie rod mounts
  • Weld in new inserts at a reduced width with smaller mid-size tie rod threads
  • Adapt a physically larger rack body to a mid-size steering geometry it was never designed to operate within
  • This is skilled machining - but it is also custom and geometry-compromised by necessity
The Real Tradeoffs
Even when executed well, a narrowed Tundra rack conversion comes with unavoidable drawbacks:
  • The rack's centerline and inner tie rod plane are different from stock mid-size geometry
  • Knuckle geometry remains unchanged, so steering feel and driving behavior are compromised
  • Knuckle steering arms remain mid-size, so steering stress + force remains the same as stock
  • Full-size Tundra tie rod interfaces are reduced to smaller mid-size threads
  • Reuses mid-size inner tie rods known to buckle & fail with just 285 tires
  • Rack-to-frame mounting hardware is reduced from 14mm (Tundra) to 11mm (mid-size)
  • No center-mount provision and no double-shear mount options
  • V8 applications require additional engine mount spacers
  • Replacement racks are custom-order only - downtime and cost can be significant
  • No right-hand-drive compatibility (Tundra is North America only)
What It Really Costs
Typical real-world pricing for a narrowed Tundra rack conversion:
  • Custom rack: $1,798 avg
  • Sales tax: $135
  • Shipping: $50
  • Installation labor: ~16 hours @ $125/hr → $2,000
  • Total: ~$3,983
And this still leaves you with:
  • Original mid-size knuckle geometry that is not designed for a Tundra rack
  • Original mid-size tie rod & steering rack stress + force
  • Original light-duty stock tie rods that fail with just 285s
  • Optionally dropping another $1,442 on clevis-style inner tie rods–bringing just your steering system cost into the same range as the full RCLT HD Kit
  • Original light-duty single-shear tie rod connection at knuckle
  • Original mid-size steering rack mount hardware
  • A custom rack that cannot be replaced off-the-shelf or found while out on a camping trip
Additional Consideration: Warranty, Assembly Responsibility & Long-Term Risk
One important factor that is often overlooked with narrowed steering rack conversions is how the rack is modified.
To narrow a full-size Tundra rack, the rack must be completely disassembled so the inner rack bar can be cut and reworked. Once this occurs:
  • The original manufacturer warranty is permanently void
  • Assembly responsibility transfers from the OEM to the custom shop
  • Seal condition and long-term leak resistance depend entirely on the rebuild process
  • The rack, even if new beforehand, is now a rebuilt unit
In the steering and hydraulic industry, rebuilt racks - even when assembled carefully - are generally regarded as higher risk than factory-assembled, pressure-tested new units due to additional human processes and variability introduced during disassembly and reassembly.
How This Differs with the Land Cruiser Rack + RCLT HD
With RCLT HD, the 200-series Land Cruiser rack:
  • Is installed without being opened or internally modified
  • Retains factory assembly, sealing, pressure testing and quality control
  • Retains OEM or aftermarket manufacturer warranty
  • Customers have made mistakes during install and had their racks replaced over-the-counter at dealerships
This eliminates an entire category of risk associated with rebuilt steering components and preserves the reliability advantages of a brand-new, factory-assembled & factory-sealed hydraulic system.
Why the 200-series Land Cruiser Rack + RCLT HD Is Different
With RCLT HD:
  • The vehicle is upgraded to full-size steering by design, not adaptation
  • A genuine 200-series Land Cruiser rack is used with no internal modification
  • Uses engineered full-size steering rack + knuckle + suspension geometry for OE-level driving feel
  • Geometry is reset from a lifted baseline for correct alignment + handling at the ride height enthusiasts actually desire
  • Replacement knuckles have full-size steering arms, so steering stress on all components is decreased
  • Two-fold benefit: Stronger steering system that also itself experiences less stress
RCLT HD does not attempt to "shrink" a full-size rack into a mid-size system.
Instead, it re-engineers the entire suspension and steering baseline so that a true full-size rack can operate exactly as intended.
More Benefits of RCLT HD / MarRack Steering
  • Steering power is increased at both rack and knuckle steering arm geometry
  • Double-shear tie rod connection at knuckle with 1-ton hardware
  • Full-size OEM 28mm inner tie rod connection retained
  • Full-size OEM inner tie rods are extremely strong and proven undefeated even with 42″ tires
  • Full-size OEM 14mm rack-to-frame hardware retained
  • Center-mount and double-shear frame mount options available
  • Up to six frame mounting bolts and eight full-size shear faces are used
  • No engine mount spacers required
  • Replacement racks are mass-produced, globally available, and far less expensive
Depending on sourcing, brand-new 200-series Land Cruiser racks range from:
  • ~$291 (budget aftermarket options)
  • ~$1,086 (Genuine Toyota MSRP [as of Oct 2025], Made in Japan + what we recommend)
That represents up to a 6× reduction in rack cost alone, before considering labor, downtime, or long-term serviceability.
The Bigger Picture
A narrowed Tundra rack is often pursued as another step in a long series of incremental upgrades.
RCLT HD was created to eliminate that cycle entirely.
Comparison Summary
Feature / Consideration         Narrowed 2nd-gen Tundra Rack              200-series Land Cruiser Rack via RCLT HD
Steering philosophy             Adapt full-size rack to mid-size system   System-level upgrade to full-size steering by design
Rack internal mods              Inner rack cut + welded                   None; 100% factory-sealed
Steering geometry               Mid-size geometry retained; rack shifted  Full-size geometry engineered into suspension system
Steering power                  Small steering arms = higher stress       Full-size arms = more power + reduced stress
Inner tie rod interface         Reduced to small mid-size threads         Full-size 28mm connection retained
Inner tie rods                  Mid-size parts; fail with 285 (33")       Full-size + HD Marlinks; proven even with 42" tires
Rack-to-frame hardware          Downgraded to 11mm                        Full-size 14mm retained
Frame mount strategy            Two-bolt single-shear only                Center mount + double-shear options; up to 6 bolts
Shear load paths                Two small single-shear interfaces         Up to 8 full-size shear faces across multiple paths
Engine mount spacers (V8)       Required                                  Not required
Replacement availability        Custom-order only; downtime risk          Over-the-counter worldwide
Right-hand drive support        Not available                             Available (global Land Cruiser platform)
Typical rack cost               ~$1,800 (rebuilt custom-machined)         $291–$1,086 (new, mass-produced)
Typical install labor           ~16 hours                                 ~4 hours (as part of complete RCLT HD system)
Total steering upgrade cost     ~$3,900–4,000 (near $6k with tie rods)    Much lower with RCLT HD; no tie rod upgrades needed
Long-term serviceability        Custom parts; difficult replacement       Simple rack replacement; reuse RCLT HD components
Internal disassembly required   Yes, opened & rebuilt                     No, installed as factory-sealed unit
Manufacturer warranty           Void                                      Retained
Assembly responsibility         Custom shop                               Toyota / aftermarket manufacturer
Long-term seal risk             Dependent on rebuild quality              Factory sealed and pressure tested
End result                      Upgraded rack but constrained by          True full-size steering strength with correct geometry
                                mid-size geometry & light-duty parts      and load paths
Want the deep-dive cost + labor breakdown?
Read: The Real Cost of Long-Travel IFS - And the Bargain Hiding in Plain Sight
RCLT HD Cost Comparison — Updated with Axles & Coilovers Included
Quick update for those following the cost comparison discussion.
We recently expanded our tech article, The Real Cost of Long-Travel IFS — And the Bargain Hiding in Plain Sight, to include required long-travel axles and coil overs across all build paths.
As mentioned in the intro, long-travel setups, whether pieced together or integrated like RCLT HD, requires:
  • Longer front axles (4WD)
  • Taller coil overs
So we added a new section with those components normalized across the board and reran the numbers.
What changed?
Even when high-end long-travel axles and coil overs are added to both routes, a fully installed RCLT HD system still comes in less expensive than the piecemeal "build-your-way" approach before those required parts are even added.
In other words, adding the mandatory long-travel components doesn't change the outcome, it reinforces it.
If you're evaluating long-travel options or comparing routes, the updated comparison is located in the "Harsh Reality" section of the article:
marlincrawler.com/the-real-cost-of-long-travel-ifs-and-the-bargain-hiding-in-plain-sight/#harsh-reality
Happy to answer any technical questions or discuss assumptions behind the numbers.
Regards,
Pic: @king3512 Lexus GX470 with #RCLTHD on 40s
