87 4runner 22re surging at steady throttle
Started by rmoore, January 04, 2025, 10:50:33 AM
rmoore
Working on an 87 22re in a 4runner and i cannot figure it out!!! It idles good, runs great while applying throttle, but at steady speeds its surging like crazy! HELP!! Searched message boards everywhere and no answers. I put a new OEM TPS sensor and its dialed. Cleaned IAC valve and throttle body. Tried a new MAF. Nothing seems to work. Any help is GREATLY appreciated!!!
OVRAROK
Have you tried unplugging tps, and see if it goes away.
rmoore
No I have not, but I will. Thanks and Ill keep ya posted.
rmoore
So... I unplugged the TPS and it got a miss in the idle (idles smooth normally)  and the surging stayed exactly the same. I also tried pinching the fuel return line and that actually made a little bit of a difference. Still a bit of surging but didnt seem to be as bad. What does it tell me that it still surges with the TPS unplugged?
OVRAROK
Quote from: rmoore on January 18, 2025, 12:56:09 PM
Tps sounds like it's functioning properly.. if unplugged, and was an improvement. I would lean towards bad/ mis adjusted tps.
Prismo
Make sure you idle is under 1000 rpm. Look for vacuum leaks
OVRAROK
The plastic elbow on air tube has a tendency to crack too..  :think:
rmoore
I checked for vacuum leaks and the intake air tube... All good and no vacuum leaks. Still going down the fuel return road. Need to check fuel pressure.
OVRAROK
rmoore
Well, I did an EGR delete and it cured the problem.
