Input shaft bearing p/n
Started by Drenmaster, April 25, 2023, 09:39:35 AM
Drenmaster
After all my research, I am pretty sure the noise coming from the trans is a bad input shaft bearing / counter shaft bearing.
I have a w56-b trans just replaced the clutch/ components but still have a rattle/knock when the clutch is not pressed in. The sound is very noticeable while in neutral and the sound picks up with the engine speed unless the clutch is pressed.
I was hoping to have somone check my part number research before I pull the trigger on these bearings.
Counter Shaft bearing 903652502377
Input shaft bearing 9036340034
Looks like toyota is the only place to get these. Cobra transmission and all state gear have stuff listed but I can not verify if they are OEM / made in Japan.
Thanks for the help.. not looking forward to pulling the trans again...
4Ruinned
Not to sound mean or anything, but you will have to pull the transmission again anyway to replace those bearings, right?
Pull it, open it and verify part numbers and order them if you can afford the downtime.
I rebuilt a w56b with a kit from Cobra transmission and all the bearing part numbers matched. But this was pre-pandemic.
I hope this helps.
Drenmaster
You don't sound mean at all. Ill be doing that to begin with, but i have a funny feeling there are Chinese bearings in there because the pilot bearing had a china stamp on it. Just trying to get ahead and research my options if the bearings in there are cheap ones.
RUGER
if yer pulling the tranny might as well replace the piolet and throwout bearings while yer at it.
RUGER :usa:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
