Truck
Started by LittleSteve, February 10, 2022, 01:56:13 PM
Wainiha
No lie.  I'm afraid to cut. I have seen weld in plates and body mount relocation kits that sound interesting though.
No rubbing yet so I'm procrastinating.
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
Gnarly4X
Quote from: Wainiha on March 20, 2022, 05:57:31 PM
Hey W.....
I've been to Kauai a couple times.  :beerchug:
I don't remember seeing any rocks big enough to cause any "rubbing"?  :dunno:
Gnarls. :usa:
Wainiha
Quote from: Gnarly4X on March 21, 2022, 02:48:37 AM
Hey W.....
There are plenty just not on any drivable trails.  Only hiking.
I mentioned it once before, I'd buy the RCLT w' the RCV axles except I'd be spending a whole lot to be a poser.
Here the beach is the regular basis.  However, it's illegal.
If moved to my house in Oregon I get that kit for my truck there.
Gnarls. :usa:
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
LittleSteve
#33
235/85/16...
They fit with only slight rubbing on the mud flap at the front. So now to find something more exciting than an advanced road pattern... ::)
Refusing to fit in or comply.
Easy is not worth anything.
Wainiha
I screwed up my quote from Ganrly4X somehow.  oh well, reply is in there.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
LittleSteve
Quote from: Wainiha on March 22, 2022, 03:53:07 PM
You replied in the quote not afterward :biggthumpup:
Gnarly4X
Yes... we can see it.  And you screwed up my handle "Gnarly4X"... LOL  :therethere:
Ganrly4X  :willynilly:
Wainiha
Oops, double screw up.  More proofreading...
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
Gnarly4X
Quote from: Wainiha on March 23, 2022, 10:57:13 PM
Hey Wainiha...
I am a highly paid "proofreader".  :gap:
I proofread my text, and eveyrday I still make mistake. :smack:
Gnarls. :usa:
LittleSteve
Oopsie
Changed out the heater control illumination bulbs and gauge cluster bulbs.
Swapped out the Ash tray bracket as it was missing the plastic guide, How? Don't know. Why? Don't know.
Also most of the dash screws are missing. Why? Don't know.
Much improved.
Also fitted radio and removed hands free nastiness.
Excuse me, my fly is undone.
Gnarly4X
Ouuuie.... that hurts my eyes.   :outtahere:
Gnarls. :usa:
LittleSteve
Quote from: Gnarly4X on March 28, 2022, 03:44:57 AM
Gnarls. :usa:
Which bit?
maxreilly
love those tires!
LittleSteve
Quote from: maxreilly on March 28, 2022, 10:25:46 PM
love those tires!
You wouldn't if you had to wheel with them.
LittleSteve
#44
Let the cleaning commence
I got carried away
Must remember to take before pictures before work commences.....  :screwy:
Very satisfying process...
Found more blown bulbs in some switches. The gauge cluster housing is broken and the clear cover is all scratched so
I will see if they can be obtained.
Need a rear view as it's smashed, don't know how.
Pass door switch wire also corroded off under the carpet but I think I have the parts to remedy that.
Still trying to figure out if the fuel gauge is goosed or whether its the sender.
It also needs a lock set... one key for ignition barrel, one key fir drivers door, neither of which fit the pass door, fuel door lock is missing completely.
LittleSteve
FIGURES...
Fuel gauge doesn't work, guess this is why. Thought it had 10ltrs in it... er no more like 50 maybe more. Was damn heavy balanced on my tit.
This was missed at ministry inspection..
This has the collywobbles.. suspect inner seal gone, nut still staked but flange loose. Torqued to 105nm sorted the play so will order seals and go again
These are seized, o-ring shagged.
Found a load of other things that can be done at a later date, like the frigged diffs, yes both of them.
LittleSteve
Fuel tank crossmember is also frigged.
To lift the bed off or not to lift the bed off :headscratch:
At this point I'm thinking flopp it, pull it all apart, cut the IFS off etc...........
I have to keep telling myself... Work truck not wheeler, work truck not wheeler....
LittleSteve
#47
So I've decided to pull the bed off to make frame repairs a little easier, can derust and paint and have it done with.
But first need to modificate the new crane first, specifically to lift cabs, bodies and beds.
It's a 1970's Harvey Frost gear driven crane with a 7ft lift height, I'm going to make it lift to 13ft.
The legs will need extending
The hook is out of an old crane, had to be trimmed down, cut two slots in the new jib for weldment.
