I have an idea, wondering if anyone has done it before. I'm thinking of adding a second set of shock mounts to the rear axle (leaf springs, rancho shocks existing) to run a pair of air shocks, the kind that you can inflate and deflate.Then I'd wire a panel to inflate and deflate either side independently.I have a few reasons for wanting this:- load assist while towing- level the truck on uneven ground for sleeping in the bed- counter off-camber situations by maxing out the downhill shockIs that last point even feasible? Would that work?Anyone used air shocks on a crawler with leaf springs before?
I wouldn't use straight air bags for reliability reasons - I wouldn't want to puncture/rip a bag and need to swap it on a difficult spot in a trail.Leafs carry the load, air shocks increase the spring rate. The failure case of a blown air shock in my mind is... well... graceful degradation to the setup I have now.I am keeping leafs (as opposed to links) because I tow regularly with this truck, and like the progressive spring rate leafs offer.Love Dave Chappelle, the guy is an understated fabrication genius. Gnarls, I think your control concerns are addressing a straw man. You could say the same about tire pressure, manual lockers, adjustable dampers, etc.If a group is behind me, I let them pass. If you're part of my group, then you're stuck with me anyways
Started by PandaCrawler Parts For Sale
Started by Jud Rigs For Sale
Started by hilux-1983 Parts Wanted
Started by dgrant71 For Trade or Barter!
Started by Lewis Hein Toyota Pickup/4Runner Tech 1979-95
