Rear 8” E-Locker Dif in in Landruiser 8“ front Diff
Started by sjelite, March 05, 2021, 07:07:57 AM
sjelite
Hey guys can I swap a rear TRD E-Locker 8" dif into a landcruiser 80 series front diff non locked axle?
If so What's the modifications and changes, necessary do you still need reverse cut gears and does the LC axle housing need to be notched and tapped?
lone walker
You will need to notch the housing, but why? It'll be better to run the hp third with a selectable than swap it to a standard pinion.
Going, going, gone
