Front axle spring perch... left vs right
Started by Eschenfeldt, November 26, 2020, 11:23:54 AM
Eschenfeldt
Is the front axle spring perch on the passenger side slightly raised compared to the driver side because it's pushed up against the diff housing? Is it just my eyes because it appears to be about an inch higher or so? I would just measure but I have a rock driveway and can't get an accurate measurement. I'm having a hell of a time trying to get my truck to sit level.
81 Toyota still figuring out what I want to do with it
toyodaaddict
Yes. The driver side perch is lower. You can add a spacer, 3/8" I think it is. Toyota used a taller driver side spring to deal with this. Most after market springs are the same height, left to right and require a spacer.
https://www.yotamasters.com/shop/axles/seals-gaskets-misc/leaf-spring-spacer-pad-38-drivers-side/
Eschenfeldt
Thanks man strange thing for them to have done I bought an old man emu kit for my truck and it seems to compensate for the difference. just glad I got the "A" and "B" sides right when I was installing it cause I hadn't noticed at that point
blackdiamond
Quote from: Eschenfeldt on November 27, 2020, 02:33:40 PM
It's really common for Toyota's to have a lean. My 4Runner has custom L and R front Alcan springs and it's has a lean.
Gnarly4X
Quote from: blackdiamond on November 28, 2020, 04:27:50 PM
Wow... I've never heard that.  I'm on my 4th Toyota truck and 14th Toyota vehicle.  None had a lean.  But 9 of them had a car payment. :gap:
Gnarls. :inthedark:
blackdiamond
Quote from: Gnarly4X on November 28, 2020, 10:43:09 PM
Gnarls. :inthedark:
I'm referring to built ones.  Most of the lifted rigs I've been around have a bit of a lean.
Eschenfeldt
Quote from: blackdiamond on November 29, 2020, 07:55:18 PM
Yeah it's annoying so I put longer shackles on to take care of the rake but what I think I'm gonna do to help the lean is use Marlins 5 inch shackles on one side and 6 inch shackles on the other side I don't know if this will cause any other issues I guess I'll find out
