Engine redlines and output
Started by Profile_Name, July 12, 2020, 09:31:24 PM
Profile_Name
Running a 20R with stock bottom end, and some LCE goodies in the head: dual springs, 1mm over sized valves, drilled rocker rods and .450 cam.
Running dual side draft weber 40s and EGR block off
What sort of new redline would i be looking at, along with power output, based on similar set ups?
Gnarly4X
#1
Speculating on "LCE goodies" and ".450" cam specs, then pulling numbers out of my rabbit hat... ???
Around 5500 RPMs will be peak HP. You can redline at 6,000+ but the HP and torque will have dropped off significantly.  :driving:
*Torque will peak between 3300 and 3500 RPMs.  :yesnod:
"power output".... being optimistically generous ....110 to 115 HP at the crank.   :crossed:
Dual 40s are probably overkill on flow.  :shakehead:  No EXHAUST mod? :smack:
Oversized valves may or may not help with flow.  :dunno:
*Depending on cam profile, bottom end torque may disappear like a flea fart in a hurricane.  :gap:
Drilled rocker rods will suck at least 1 HP.  :willynilly:
Gnarls.  :beerchug:
