Energy Polyurethane Bushing master kits any good?
Started by FjordWarrden, May 03, 2020, 11:54:59 PM
FjordWarrden
Hi, I have been taking apart the front end of the 4runner, and thinking that after 215k it may be time to replace the suspension and body mount bushings, any way I was wondering if anyone has used the Energy suspension hyperflex master bushing kit. Particularly the control arm bushings? Im concerned about the increased harshness of the ride and about the compatibility of PU for contolarm bushings.
Snowtoy
Used energy suspension mounts on both the '90 and '91 X-cabs, and experienced no harshess in the ride or increased vibration in the cabs.  Also used the bushing kit on teh conttrol arms on the '90, nop issues there either.  The control arms are a PITA to do, found torching the bushings out was the easiset/best way to get them out, and freezing the new bushings is the easiest way of getting them back in.
FjordWarrden
Wow, Thank you so much for the info on the Energy suspension bushings. Ill go ahead and add them to the list. The control arms do look pretty terrible to deal with but they can't be worse than the ball joints I just dealt with. I had to literally use a jackhammer to get them to release. It was small jack hammer,as jack hammers go, but non the less ridiculous.
Snowtoy
Never had that issues with ball joints, but having done that, you are prepared for the amount of work for the contol arm bushings.  When I replaced the ones on my '90, I did teh lowers, then a few months, maybe it was a year later, did the uppers.  When you do the upper control arms, you will want to have new torsion bolts and nuts on hand, even in CA w/o a rust issue, I had one strip on me.
FjordWarrden
good to know. Yes the ball joints were very suborn. I think it was because the truck ha been sitting for 6 years before I rescued it. I imagine that driving keeps the ball joints from getting to stuck because of the constant changes in pressure, heat and vibration. Having looked at my lower bushings, the ends seem to be soft still and un-cracked. I'm not sure exactly how to check them but they seem fine for now.
RUGER
while were on the topic of bushings what do yall think of prothane.
RUGER :usa: :beerchug: :usa:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
FjordWarrden
Wish I could say, but I have no experience with Prothane.
RUGER
me neither. that's why I was asking since its cheaper then energy
RUGER :usa: :beer: :usa:
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
NRA life member
Snowtoy
Quote from: RUGER on May 06, 2020, 04:14:11 PM
me neither. that's why I was asking since its cheaper then energy.
At nearly a $60 difference and both claimed to be made in the USA, I would give them a try.
FjordWarrden
I read during my research that the Prothane is much stiffer than Polyurethane, and probably way stiffer than the energy hyperflex bushings.
Gnarly4X
FjordWarrden
Excellent article, good information presented in a easy to understand format. I took a look at my bushings and the control arm bushings appear to be fine, no cracking or excessive play or stiffness. my anti sway bar end links are another story, as are my body mounts .
RUGER
good article gnarls.
that you fer the info on prothane.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
NRA life member
Jaymz11
ive used them on all my vehicles both sport and 4x4.
they are unmatched regarding handling and control of you rrde
