Hello all, I’m new here but not new to projects. I look forward to any help you all can provide. I can usually figure my way through my projects since allot of it is common sense. But I feel for some reason with this issue I am lacking in both common sense and patience right now... Now to why I am here..
I am installing an Allpro Hy-Steer on my 85 4runner. The problem I’ve run into is concerning the Allpro IFS steering box mount I am using to mount the IFS box. The kit includes 2 plates with five 3/4” holes, and two larger approximately 1.25” holes drilled in them. Can someone show/tell me how these plates are intended to be used? I know they weld to the frame to mount the ifs box. Common sense says that three of the 3/4” holes should line up with the steering box mount holes, but there is no combination of these 5 holes I can find on the plates that match the ifs box. The only holes that I can find that fit the box holes are the one 3/4” hole that mounts overtop the frame rail and the two larger holes would be used for the lower mounting holes where the 3/4” tubes go through the frame. This makes me think that the plates were designed to use the two larger holes, and using these should allow for room for the weld around the tubes through the frame and for a weld between the plate and the frame.
Any help with using these particular Allpro plates is appreciated! I can’t seem to find a photo of them being used anywhere.. They seem engineered for some use & are made pretty nice but I’m struggling to see how it is... and if this is how they are used then now I have a bunch of 3/4” holes in the plates (4 of them) that I’m not going to use....
And I know.... after doing more research I really like the look and design of the Marlin mount.
![Hammer :hammer:](https://board.marlincrawler.com/Smileys/marlin/hammer.gif)
