The never ending project
Started by cruzila, August 19, 2002, 05:53:42 PM
0 Members and 17 Guests are viewing this topic.
cruzila
#60
It is mine on a cruiser axle. Front range does not do a cruiser setupI think.
#61
:bowdown: you da man :~~: so how hard was it?? and what did the axles cost ya? :dunno:and could you make one for a pickup cheaper than front ranges $700, for adapter and axles :smack: and i still have to find all the parts,spindle,hub,bearing,locking hub :smack:
cruzila
#62
Man oh Man I spent 400.00 on custom axles.
#63
:ack:OUCH   i guess there price isnt all that bad then :smack:
cruzila
#64
So after 4 months wheeling season is upon us and I decided to just put the old stuff back in. I went with 2.28 gears for now.
cruzila
#65
 :clap:
Bringing the zilla back to life here. I just spent the last couple days going over Cruzila.
Last August I hauled a Kubota into Rubicon Springs and had an axle break.
I could not get the inner shaft out on the trail and I have not moved the rig since it came back home. Today I'll take the axle apart and replace the birfs with 30 spline Longs :woohoo:
I also redid my main batteries with a marine switch and new 2/0 wires.
cruzila
Rolling around under the rig last night I spotted a problem. :yikes:
cruzila
#67
I had purchased some seats from Roundeyes for another project,  but I think they need to go into cruzila. :yupyup:
new seat :yesnod:
talk about a OLD post
cruzila
Well after dismantling the front end I can say routine maintenance is a good thing.
One birfield trail fix rubbed the end of the birf. The martack was sheared when it broke.   :shocking:
The other was close to failure. the star had major chips off the edges.  :crazy:
Two upper knuckle bearings failed one was worn bad and the other died of water poisoning. :reg:
One outer wheel bearing has wear, daylight will tell if I can keep it.
I have not even pulled the third yet, the ARB was having leak issues for about a year.
I'll take a few shots tommorrow.  :goodnight:
:sofa:
when you gonna make me some fullfloat adapters :dunno:
cruzila
#71
Bringing an old thread back to life.................aaahhhhh :beerchug:
Well, here I am again repairing damage caused by excessive wheeling.  :smack:
I have ripped the bumper off and inspecting crack.
Going in for the Roundup this year, I was feeling something in the steering wheel when I heard a popping noise. I looked at the frame near Little Sluice and decided to go with it as the frame was cracked and just hitting the steering shaft. I ran it all the way in and out and home with no issues. I am glad to have not had to fix it out in the field.
I have decided to make a new bumper and plate the outside of the frame to strengthen the front 2 feet of the vehicle. I found out it was much worse than I thought.
cruzila
Bad focus, but you can see the part that was hitting the steering shaft.
i have a few more repairs going at the same time. I hit the dial face on a lockout hub so I need to replace that. I found a crack in my skid plate t-case mount. So I fixed that. Looking at some of my original welds, I see I sucked at welding stick so I will fix those too.
cruzila
New bumper. I have an 8274 winch so I need to remake the mount. I got some 2x5 and made a couple cuts and welded the m together. Then welding all that in the opening for the fairlead. I made some round spacers so the winch mount will be backed up too.
I need to take some more pics tonight.
cruzila
