Ultra 4, 4400/4800
Started by superyota, February 25, 2019, 04:32:36 PM
superyota
Lambert Motorsports 1.5" Chassis. This chassis has already been through tech, is banded for Ultra 4, and grandfathered in. Very light rig, and lots of power.
-LQ9, 397 rwhp
-Texas Speed custom cast PRC heads
-Comp Cam
-Sanderson Block hugger headers, with new 2.5" exhaust.
-TH350 transmission, rebuilt with lots of upgrades, and gone through 2 years ago
-Atlas 3.0 transfercase
-Spare front and rear drive shafts
-Front axle is a Dynatrac HP ProRock 60, 5.38 gears with Spool, Yukon 35 spline inner and outer shafts, Yukon spindles, bearing hubs, and drive slugs. Solid Axle Industries knuckles with new Dynatrac Ball Joints.
-Rear axle is a Spidertrax 9", 3.5" tubes, full float with new Yukon 5.43 third member with spool. 300mm, 35 spline axle shafts made by Performance Cryogenics, Yukon bearing hubs with drive slugs.
-Fox 2.5 x 14" coilovers at all 4 corners
-Fox 2.0 x 4" bumps at all 4 corners
-GM 3/4 ton brakes at all 4 corners
-PSC 2.5 full hydro setup, trussed ram mount, new P-style pump.
-New Rugged Radios coms
-Pumper
-JAZ 30 gallon fuel cell
-Dual Walbro in-tank pumps with Hydramat
-Griffin dual pass engine coolant radiator with Spal fan.
-Griffin dual pass trans cooler with Spal fan.
-Corbeau Seats
-5 point harnesses
Lots of other let's I'm sure I'm missing. Lots of extra parts to go with it also.
Asking $35k obo.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
superyota
ABD Motorsports
#4475
KK6QDW
