86 Turbo 22ret SAS Pickup R151f
Started by Ohio4Ru88er, February 21, 2019, 07:11:47 AM
Ohio4Ru88er
Have too many projects started and tired of seeing the 22ret with the R151f sit. It has a solid axle, lift, the turbo 22re, R151f, and a flat bed. 37s. Would keep them for less. Have clean title for it that matches vin on dash and says turbo pickup. Solid frame other than cross member is a little soft. Under doors rusty but the engine trans and driveline is where the value is. Plus a turbo title. Truck is located outside of Dayton, Ohio. Will sell for $4500. Bought with plans for full restore and started two other projects first. My loss your gain. Serious inquires only - Dont waste my time offering $3500. I will let it sit and build it next winter. Just running out of time before spring and willing to break even to not see it sit all summer. Add is attached.
https://dayton.craigslist.org/cto/d/conover-86-toyota-turbo-sas-22ret/6816405935.html
88 4Runner SAS marlin dual cases, locked, 63s, cammed, port polish 22re, gears, RCV shafts, 36 tsl.
82 Hilux 3rz swap R150, Elock rear, 63s, gears, 35 bfg's
98 4runner 3in lift, e locker, 33 bfg's
