R452 Gearbox
Started by Di0n, December 01, 2018, 11:57:03 PM
Di0n
Hi there,
I've just purchased a 1994 Toyoace truck with the diesel 3L and R452 gearbox. Everything I've read so far online relates to using parts of this gearbox to modify or change the ratios of the other R15* gearbox's. But what I am looking to do is bolt a transfer case to the stock R452 gearbox in the truck. Does anyone know if it's possible?
Cheers
TURBO
The R452 is typically assembled with a cast iron, side shifting front housing, and a drum parking brake behind the cast iron tail housing. There are 2 options. Divorce the t-case, or modify the transmission. Divorcing the t-case might prove challenging, as I have heard the business making the divorce adapters is no longer around. Modifying the transmission will require a donor transmission for parts like housings and shifter linkages. The conversion you want can easily be done at Marlin Crawler. Call the sales line to get put on the build list. 1(559)252-7295
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
