mudmaster's 83
Started by mudmaster, April 10, 2005, 06:04:39 PM
mudmaster
Frame was already plated on the inside. I had my hoses made locally with a 90 on one end. Ram is from the Surplus Center.
Time to go wheelin!
mudmaster
Got the offending rear caliper swapped out. Old:
Time to go wheelin!
mudmaster
New one on with some EBC pads.
Time to go wheelin!
mudmaster
Went to Elbe a week and half ago. We had some snow overnight.
Time to go wheelin!
mudmaster
Also was coming down while we were still out wheeling.
Time to go wheelin!
mudmaster
I was backing up and a stump attacked me.
Time to go wheelin!
mudmaster
It crushed the passenger side rear shock. Time to finally install the AP rear springs.
Time to go wheelin!
mudmaster
And so it begins........
Time to go wheelin!
joeyf
Very nice, got to be Stoked on new springs. Any thought on inboarding them.
mudmaster
No. Don't see a need to.
Time to go wheelin!
mudmaster
Front hanger tacked on.
Time to go wheelin!
mudmaster
Rear hangers tacked on.
Time to go wheelin!
mudmaster
Got the rear springs installed as far as I could. AP didn't ship all the parts  :shake:
Time to go wheelin!
mudmaster
Got the new hangers burned in and painted.
Time to go wheelin!
mudmaster
Ended up with a 25* angle.
Time to go wheelin!
mudmaster
Spring perches are now burned in and painted too.
Time to go wheelin!
mudmaster
Back on the ground. Just need to fill the diff and install shocks and the rear is done.
Time to go wheelin!
mudmaster
The rear is done. Now on to the front for the 25mm pin and Taco brake upgrades, plus some much needed maintenance.
Time to go wheelin!
mudmaster
Everything is torn down. Now to clean and figure out how to get it all back together.
Time to go wheelin!
mudmaster
Cleaned and going back together......
Time to go wheelin!
mudmaster
Getting there.....
Time to go wheelin!
mudmaster
Passenger side almost complete.
Time to go wheelin!
mudmaster
Thanks to BestGen for the help on the driver's side shaft it is now at the same step as the passenger's side.
Time to go wheelin!
mudmaster
Both sides are complete and need the brakes bled and then fill the diff.
Time to go wheelin!
OVRAROK
What year, and  Model did you order new brake rotors, and calipers for? And do they fit 15" rims
mudmaster
The calipers are from a 2000 4Runner. I can't remember what years the rotors are from, but I can look it up when I get home for ya. I've heard they'll fit 15s depending on the wheel. I think SqWADoosh had 15s on Red and had to grind the calipers??
Time to go wheelin!
SqWADoosh
Quote from: mudmaster on May 08, 2018, 05:55:09 AM
I did. I recommend running 1.5 spacers. So nice and planted that way anyways. Especially on trailer rig.
mudmaster
Front end upgrades are complete.
Time to go wheelin!
mudmaster
Got started on the trans temp gauge yesterday.
Time to go wheelin!
mudmaster
Gauge install is complete and working.
Time to go wheelin!
