mudmaster's 83
Started by mudmaster, April 10, 2005, 06:04:39 PM
:)bestgen4runner
Took on the challenge of fixing Mud Masters "Marlin Crawler built" 4.7 transfer case.
Here is the cross threaded nut that I had to cut off using an air hammer.
I am not going to bash or point fingers in any way. I'm just going to state facts and show You what I found.
Maybe someday this will help somebody out.
Hogcanyonhopper  :thpst:
I am 1/5th of Perfect Fit
:)bestgen4runner
#331
You can see the damages caused by limit clip never being installed.
The 4th picture shows the clip installed correctly on a different transfer case.
The clips is there to limit the forward movement of the lower shaft and bearing.
Without the clip in place it allowed the bearing and large 4.7 gear to move forward and contact the case.
You can see from the picture the large circular grind marks in the case. these are not part of the clearencing process for the 4.7 gears. You can also see around the outside of the pocket bearing where the opposite side of the large 4.7 gear, the shaft side was contacting. I suspect this is due to the large gear kicking back in the case when it would contact the forward case. Mud Master had also pointed out to me that He had heard a bump bump type of noise. I believe this noise was caused by the large 4.7 gear bouncing forward and back.
:)bestgen4runner
Here are a few pictures of the cleaning and reassembly  process. Mud Master had Me install a RCV rear output shaft.  Very nice piece.
Note, The RCV upgrade output shaft has no oiling holes. This was strange
I placed a call to RCV and they said that is how they make them and that there is no issue.
Good enough for me.
:)bestgen4runner
So after diagnosing what went wrong with the original build, cutting off the cross threaded nut, replacing the missing clip, cleaning out all the metal shavings, installing a new upgraded output shaft, and
replaced all the gaskets.
Mud Master Again has a "Marlin Crawler 4.7 transfer case" this time built by BestGen.
:)bestgen4runner
I almost forgot to post pictures of all the metal I found inside.  :smack:
mudmaster
Thanks for the rebuild Bestgen!
Time to go wheelin!
mudmaster
Got my cup holders installed last night.
Time to go wheelin!
oleblue22
Nice! Where did you find those?
mudmaster
I've had them too long to remember, but it looks like Desert Rat has them:
http://www.desertrat.com/products/?id=4105
Time to go wheelin!
mudmaster
Elbe 3/25/17
Time to go wheelin!
mudmaster
A little scenery
Time to go wheelin!
mudmaster
Found a deep hole
Time to go wheelin!
mudmaster
Some flex
Time to go wheelin!
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
mudmaster
Time to go wheelin!
mudmaster
Got the hydro assist installed finally. Old junkyard sourced box is out.
Time to go wheelin!
mudmaster
New  (PSC) and old.
Time to go wheelin!
mudmaster
New (PSC) box installed.
Time to go wheelin!
mudmaster
Top view.
Time to go wheelin!
mudmaster
Bleeding.......
Time to go wheelin!
mudmaster
Done and no leaks.
Time to go wheelin!
mudmaster
So since I bought this truck it hasn't had a proper ignition switch on the column. I decided it was time to fix that issue. Finding a new steering lock mechanism proved to be impossible as mine was bent and cracked where the switch wiring resides. I found a used one with a key at a local junkyard and ordered a new ignition starter switch on ebay.
Time to go wheelin!
mudmaster
Everything is off here
Time to go wheelin!
mudmaster
Old steering lock mechanism .
Time to go wheelin!
mudmaster
New to me one with new ignition starter switch. Still haven't got it all installed yet........
Time to go wheelin!
mudmaster
Getting it back together.
Time to go wheelin!
mudmaster
Getting closer
Time to go wheelin!
mudmaster
Just about there.
Time to go wheelin!
mudmaster
All done and it works!
Time to go wheelin!
Willard
What ram and hose kit did you use? I also have the PSC box and they placed the port on the front the same on my box and it is going to be a PITA to hole saw through my body mount to run a hose to it because my box is so far forward. Are you planning on plating your frame for the box or am I not seeing it if it is already there? Nice job BTW.
