Replace lock cylinder and wiring. Cranks but won’t fire
Started by Dharris912, September 09, 2018, 12:51:00 PM
Dharris912
Title pretty much says it all.  Someone stole my 91 Toyota and drill out the ignition cylinder and internals.  Took the internals out of my parts truck and everything works great except when it turns over it doesn't fire.  Any ideas would be helpful thanks
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Snowtoy
Have you checked the ignition fuse inside the cab?
Check the ignition switch.
Dharris912
Yeah I just checked the fuse.  Before I put the new lock cylinder in and the wiring behind it I was just hot wiring it with bare wires. Figured it should work the same putting it back to stock.
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Snowtoy
Check to see if you are getting spark at the spark plugs, to determine if the issue is related to the ignition or something else.
Dharris912
No spark from the coil.  Might have put the internals in backwards. The wheel unlocks in the lock position lol
I'm going to post some random stuff to clear my 11 posts.  I'm an old member I just don't remember my password or old email. I'm BHT12
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
Dharris912
1991 2wd Toyota
2003 Cummins
1984 Toyota
1991 Toyota ex cab
