Nothing new
Started by joeyf, June 20, 2018, 11:36:21 PM
joeyf
Two have 5.29 duals with 4.7, the other has 5.29 toy reduction box to d300
joeyf
Not much done with still working on my rig. But I did get my boss to turn out pucks so I can slide a bar through to see how straight it is. They were real close, just a little tweaking with the bottle Jack and they are ready to weld out.
:)bestgen4runner
I am 1/5th of Perfect Fit
joeyf
Some small progress. Spacers welded, ball gussets and spring perches welded out.
Plated the diff.
Rotated the diff 12 degrees from stock. But with how the leafs are mounted it will rotate back  3.
joeyf
Starting the ram mount.
joeyf
Finished the mount. Will finish welding it to the axle sometime this week.
joeyf
This should help quite a bit.
Slabzilla
You have serious control issues, the kind I like.  I like that you widened the axle, too, nice work.   :biggthumpup:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
joeyf
Thanks. Would have liked to do the front range keyed arms but this way was dirt cheap and because of that, I was able to order my shafts.
joeyf
Shafts finally showed.
:)bestgen4runner
Looks like it's coming together nicely.  :thumbs:
Slabzilla
I can almost see this thing churning with some big meats.    :yikes:   :biggthumpup:
joeyf
Crawlerbrennan2
Crawlerbrennan2
Did your buddy give it to you or are you just a really good friend?
joeyf
Quote from: Crawlerbrennan2 on March 17, 2019, 11:53:26 PM
Nice work
Quote from: Crawlerbrennan2 on March 17, 2019, 11:54:51 PM
Thanks. Not given to me, just good friends.
joeyf
Buddy pulled off the fairlead from the donor rig and dropped it off. Looks like the grill will have to get reworked so it doesn't get bent up by the line.
Really didn't want to put a tow point on the front end but the only place to throw a strap is right under the grill and it would most likely slide up and crush it. So I just added one.
joeyf
Cheap mans hi pinion. Shooting to having it be a roller at the end of the weekend.
joeyf
Full lock with 4Ds with no rubbing on leafs, while keeping stock scrub.
