Awesome - thanks for the quick reply!I did not pull the case apart but just looking through the shifter hole, you can see the gears are pretty chewed up. The truck still moved but jumped like a rabbit. Should have tore it down but I'm guessing it is a total loss in there. I will need to see if I can figure out what gearing is in there, I would guess they are 4.7 as is crawled quite slow in low/low. I'm guessing i will need to buy a new complete 23 spline 4.7 gearset. Looking at the Marlin website, no gearsets appear to be available. what gives?
cool. i did the appropriate thing and called the prior owner. Stock gears in the crawler box and reduction in the rear. I'm just going to buy an entire new case with reduced gears. I fear i would mess up going the gear replacement route...
I think I am going to take on the gear transfer on my own. Wish me luck!
Started by BigMike « 1 2 » Engine
Started by mmessier2 Toyota Pickup/4Runner Tech 1979-95
Started by desrodunes1 Parts Wanted
Started by garlicgabe Parts Wanted
Started by gunrgood Transfer Case/Drive Line
