So you think you are burning coolant from an internal leak...
warm up the engine, turn off engine, pull all 4 spark plugs, put cooling system pressure tester on and pressurize for 4hrs or more while checking and making sure it stay pressurized every hr or so. Then look through spark plug hole with boroscope to see if coolant is in cylinder
probably doesn't apply in your case since you have a steam cleaned plug but full synthetic oil will burn white also
I'm running Castrol 10W-40. Unfortunately I'm unable to post a picture, because I'm not able to reduce a image below the max of 140kb.
Or.. just pull the head. Heads and head gaskets fail at 165K miles.
synthetic oil has a white/gray smoke when burned in the combustion chamber, conventional oil burns blue. that's been my experience. point is, white smoke doesn't always mean coolant
... A valve stem seal could be bad also, I have not written that off yet either.
... When I get a few more posts I will upload images of the smoke from the exhaust I get during the initial start up and the conditions of the spark plugs.
... I'm going to buy a radiator coolant pressure kit from Harbor Freight ...
Started by toybuilt « 1 2 » Rig Gallery
Started by 79-83earlyota Toyota Pickup/4Runner Tech 1979-95
Started by 8D3TOY Engine
Started by mlatrella Toyota Pickup/4Runner Tech 1979-95
Started by Groundpounder17 « 1 2 3 4 » Engine
