Thanks. Any reccomendation for a lift? I might go smaller on the tires and buy Marlin's 4" Springs
the 34's will run the springs,,with 34's you need a 7 in wheel to run them reliably with out bead locks..I see them blow all the time with a 8 in wheel at 10 psi..with the 7 in wheel your off set sucks and will rub your springs..spacers will be needed to clear the leaf springs while turning in the front..
untill you get a more powerful motor then that pathetic 22r i wouldnt go much larger than 31-10.50s the sad thing is that a 350 swap in to your truck would give you the same gas mileage
spacers on a daily driver is just a bad idea. i have seen a few spacers fall apart with normal on road driving
huh? i get 24mpg on the freeway with my 22R with my heavy swampers, and don't have to worry about smashing stuff with a 350. not to mention that 350s suck and are overdone.
Anyone running aset of TSL s? How to they compare to others?
would a set of 15X8's solve the problem or should i get beadlocks?
Started by Yota4life Parts For Sale
Started by RAZOR Parts For Sale
Started by Joe S. Parts For Sale
Started by sandboxtoy Parts For Sale
Started by monyman Parts Wanted
