Author Topic: 81-83 T-Case  (Read 1194 times)
SethPDX
  • Turtle Points: -15
  • Member since Jan '18
81-83 T-Case
« on: Jan 30, 2018, 10:31:39 AM »
Hello, new to the forum and newb to building.
Found an '81-83' t-case on Craigslist, thinking of buying it to eventually throw it in my '79 pickup.
I would think they would bolt on with an adapter plate, but I want to be sure before I spend the cash.
Am I wrong?
Thanks!
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
Re: 81-83 T-Case
« Reply #1 on: Jan 30, 2018, 11:41:47 AM »
Assuming your '79 is a 4WD...
It would be the same t-case that came on your '79 as far as how it fits.  There is a difference in how the input shaft is shaped.  The '79-'80 has splines all the way and the '81+ has a "fuse" where it necks down so it is a little weaker.  Not a big deal unless you are making a huge crawler out of it.
– Steve McQueen
SethPDX [OP]
Re: 81-83 T-Case
« Reply #2 on: Jan 30, 2018, 12:21:53 PM »
Thank you for the reply,
Not at the point where I'll be seriously crawling this rig. But it does look like Marlin sells an aftermarket input, meaning a possible upgrade?
Also, yes, it's a 4wd.
H8PVMNT
  • Male Posts: 3,554
Re: 81-83 T-Case
« Reply #3 on: Jan 30, 2018, 02:28:13 PM »
Yes but I think you will be fine to use he stock input.  If you can score a gear drive t-case these days get it.
– Steve McQueen
T-Revv
  • Turtle Points: 722
  • Male Posts: 280
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
Re: 81-83 T-Case
« Reply #4 on: Jan 30, 2018, 04:47:37 PM »
So some clarification.  In 1979 the tcase that connects to the L43 transmission  does not have a neck down, but it has a shoulder to hold the coupler in place.  Without that shoulder the coupler on the L43 can walk out.  You can use a later model transfer case, but you would have to either still use your same input or use a sleeve or something that would prevent the coupler from walking.  Marlin Crawler does not make an input that will work with an L43.  The Total Spline input you are referencing is different than the L43 transmission input, neither have a neck down, this true, however the total spline runs the splines all the back on the neck, the L43 has the same length spline as any other input it just has shoulder where most have a neck down.  Marlin Cralwer only makes Total Spline inputs for 23 spline, unless you're going to a 4.7 ratio, all Marlin 4.7 gears come with a Total spline input.
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
Last post Nov 20, 2005, 05:19:12 PM
by Marlin
Last post Aug 13, 2008, 08:55:24 PM
by focushere
Last post Feb 06, 2012, 07:24:57 AM
by 4RunnerChevy
Last post Apr 21, 2013, 08:02:26 PM
by ryan_ackerman
Last post Apr 07, 2015, 09:09:07 PM
by Poorboyz
