Franken-Willys needs new R&P
Started by Franken-Willys, January 29, 2018, 11:28:39 AM
Franken-Willys
OK, here goes... I 've got a '56 Willys Wagon with a Chevy 327 (210 HP), Turbo 400, and NP 203 boat anchor. All that awesome power reaches the ground through 33s, on '85 Toyota axles with 5.29s, hanging spring-over from Wagoneer leafs on the original frame (slightly modified). My wife and I bought it years ago with the intention of family wheeling up in the hills - fire access roads and the like, no rock crawling. Because it's an old Willys, we also show it off each year at Hot August Nights in Reno. Here's the issue: because this rig spends more time on pavement getting to its destination, the drivetrain combo winds out the small block at 65 mph! I've done ALOT of research on how to better suit it to our needs, but well-intentioned opinions have left me without solid answers.
Option 1. Swap TH400 for 700R4. This would give me overdrive, and drivability on the highway. However, this is a short wheel-base vehicle, and a longer trans would create a greater pinion angle. No bueno.
Option 2. Swap body onto modern chassis. :rofl2:
Option 3. Swap dropouts for new ones with 4.11s. Easy enough for a novice wrencher like me. Better highway manners. Maybe better mileage. But, would my "off-the-line" performance suffer? I'm not drag racin', but I'd like to be able to get out of my own way!
Any thoughts? Regardless, I will be replacing all the axle seals, since they're original and don't hold fluids in very well.
Slabzilla
My 4:10's in my 3/4 ton Chevy truck with a 350/350 combo got off the line pretty well with 36" Ground Hawgs, so I don't think your little Willys should have any problems scooting along on 4:11's.  5.29's are too low for your combo unless you spend all your time rock crawling or get 35" or 37" tires. Nice rig, show some pictures.   :welcome:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
Franken-Willys
Thanks for the info. Larger tires would require new axle shafts. I've been told the stock Birfields can't handle anything larger than 33s. Working on the pictures.
redneckcustoms13
If you aren't acting a fool you could get away with 35s. If you drive it like a 16 year old your in jeopardy on 31s with the torque of the sbc in front of them.
I would certainly say go for a 700r4. It's only a few inches longer than a t350
01 double cab hunting truck
06 tacoma street truck
