motor and trans mount noise . . .
Started by xcuzzi, December 15, 2017, 08:56:19 AM
xcuzzi
I am thinking of going to the solid type (urethane) motor and/or trans mount to minimize movement in the drive train. I replaced those mounts several years ago with OEM type but there is quite a bit of wobble even driving down the freeway.    I have put 50K miles on this car in 5 years so I do drive it.  I am also concerned about any adverse effects these mounts may have.  By the way,  I have deleted carpeting in the car and have used truck bed liner and rubber mats through the whole interior.  Also I have replaced the door panels etc. with sheets of black ABS plastic so it is a bit noisy anyway.  I realize there will be some additional transfer of drivetrain noise and I am trying to get a handle on how bad that will be.  Any comments would be appreciated.
first Toyota 4Runner project . . .
300k
I'm kinda in the same boat only I really don't care about noise or vibrations because I hate tearing up stock rubber mounts. I did read on here that HD transfer case mounts resonate and vibrate really good with the stock hollow tcase crossmember, and the fix is a plate crossmember. :dunno:
redneckcustoms13
Dash vibrates like crazy with the urethane mounts. Replace with stock mounts and weld a chain between the frame and upper mount limiting it from flexing too far.
01 double cab hunting truck
06 tacoma street truck
OVRAROK
I would keep stock rubber mounts.  :twocents:
Slabzilla
Keep the stock mounts and do the Mar-mount mod to the driver's side, works on the T-case mount too.   :twocents:  Works for me.   :thumbs:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
xcuzzi
so it the Mar mount mod this:
"stock mounts and weld a chain between the frame and upper mount limiting it from flexing too far"
I used the Search Mar mount mod and found nothing . . .
300k
Quote from: xcuzzi on December 26, 2017, 12:06:59 PM
Nope! Marmount is found here : http://board.marlincrawler.com/index.php?topic=95884
xcuzzi
Thanks for the "heads up" 300,  I am definitely going this way.
I saw at the end of the post a guy also did his T case mount that way . . .
What do you think of that ?
