4.7f-2.8r swap
Started by ACLakey, October 07, 2017, 04:18:29 AM
ACLakey
So I recently purchased an 87 Toyota with a 4.7 front case and 2.8 rear twin stick. In the past I had the same setup only in the reverse order, 2.8 front and 4.7 rear. Can I simply change the order of the cases or do I need to swap the internal components? I
Sent from my Pixel XL using Tapatalk
OTO Phil
I think you'll have to figure out what spline count you have on each case for input and output... If everything is the same, then yeah, you should be able to swap the cases if that's what you want to do
