Make tranny shifter longer?
Started by Yota4life, April 07, 2005, 01:44:38 PM
Yota4life
I have a 3in body lift so the tranny shifter sits pretty low, id like to raise it just 2 inches. I cant figure out how to get that long black thing off of the shifter rod. Maybe some of you have suggestions on what i can do to make a bit longer. I also want to make it so its bent more towards the driver.
Thanks
Nathan
BLUCRUZ
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
Yup, with my flat belly and a 3/4" body lift the shifter is about 6" under the level of my shoulder....
Uncle Jesse
I believe the upper (black) portion of the stock shift is epoxied onto the lower part.  Maybe heating it up would loosen it so you can remove it.  Or maybe some big vise grips and twist.  I think the threads for the knob are 12x1.25 mm (maybe 1.50 cant remember), so you could always make an extension using a nut to thread on then some round bar.
scheid6996
Its a redneck thing
"Nobody Loves Me"
toyhatsu
I had a hard time getting my shifter bent right and a comfortable height.  I added four or five inches to the length and bent it in quite a few places.  I took a cut off wheel in the angle grinder and made three cuts 3/4's of the way through.  Then bent it, welded and ground the welds down.
1991 Daihatsu Rocky, 3RZ-fe, Marlin super heavey duty clutch and pressure plate, Marlin W56-C-HD, duals, Marlin twinstick, three link front with Fox AirShox, 35's, Toy axles, 5.29:1, ARB F&R etc.
scheid6996
Its a redneck thing
"Nobody Loves Me"
toyhatsu
The hoop goes with the one on the front transfer case...to pad lock it in reverse and low.
scheid6996
Its a redneck thing
"Nobody Loves Me"
kyle_22r
that's a pretty danged cool security idea :idea:
84runner
I believe that Marlins short throw shifter kit will give the hieght you are looking for and shorten the throw all in one. Look into it
Yota4life
Quote from: 84runner on April 07, 2005, 11:24:42 PM
I could take it out, cut and weld it but i was thinking if i could find something to thread over the shift knob part that will extend it like and inch or two.
And 84runner i thinkt he short throw is only for the t-cases...I wish they made one for the tranny
89 toy
Quote from: Yota4life on April 07, 2005, 11:38:58 PM
seen these at truck stops
Yota4life
#13
Did a little search and Wallaaa! At the bottom of the page NWOR makes a shifter extension for body lifts. http://www.northwestoffroad.com/newproducts/newproducts.html
Yota4life
I called them up and its 50$! too much for my taste. Ill have to make my own
Uncle Jesse
like I said, take a piece of round bar and weld a 12x1.25 nut on one end.  Thread onto shifter.  Done.
