do you have the exhaust bracket, block to pipe
I can't think of any part that connects the engine block to an exhaust pipe. Do you mean the exhaust manifold of the EGR system? I have both, and they are the only things I can think of that connects any part of the engine to any exhaust-related pipe. If you mean something else, would you mind describing it more?Thanks.
I tapped the head for threaded inserts and then used stainless 3/8 threaded rod and locking flanged nuts (cheaper than stock 10mm)Also make sure your manifold is warped, I had to resurface mine.(It's possible to drill and tap the head in the engine bay......)
.... An easy fix is to get the next size larger "standard size" stud and retap the head.
Here's a pic for you
If there's some thread left, just jam nut it................
Unfortunately, I don't think there's enough thread left to hold a jam nut.
I actually don't think you need an exhaust manifold
In fact, with my percheron swap kit, you don't even need an engine.
If you go full Percheron, you won't even need your truck!
The trouble is, percherons don't get very good grass mileage.
Started by Makohon Project Research and Build-Ups
Started by porkchop Engine
Started by Toy Truck Parts Wanted
Started by LD Parts For Sale
Started by CrazyYota Parts Wanted
