Author Topic: Transfer case gets warm  (Read 2123 times)
Lewis Hein
  • Shoutbox Ban
  • Turtle Points: 273
  • Member since Feb '17
  • Trying to equal the wonderful one-hoss shay
« on: May 03, 2017, 08:56:25 PM »
Hi Marlinitic Crawlerites,
I have a brief question about transfer cases. Today, after a 20 mile drive in 2H, I backed the truck in 4LO (actually 2LO because the hubs weren't locked) into it's parking spot. When I did this, I noticed a funny grinding noise. And then I noticed that the T-case shift lever felt warm to the touch. Not hot, but noticeably warm and warmer closer to the T-case.
Is this feeling warm normal for the T-case shifter? I feel like in any case there is an oil change in the near future of this T-case.
Thanks,
Lewis
knapp870
  • Turtle Points: 2
  • Member since Oct '17
Re: Transfer case gets warm
« Reply #1 on: Nov 28, 2017, 06:50:53 AM »
Sounds fairly normal to me. However, i'd def check fluid level and if there appears to be any metal in the fluid as it's possible some bearing(s) might be bad.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #2 on: Dec 02, 2017, 08:17:21 AM »
Nothing to worry about, lots of gears turning and they get warm. Make sure your fluid is topped and clean!!
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #3 on: Dec 02, 2017, 12:04:36 PM »
I would expect it to be at least as hot as the transmission or rear differential.
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,236
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
« Reply #4 on: Dec 03, 2017, 06:21:12 AM »
Both my 5-speeds, this one in my 1986 and my old 1985, the t-shifter would get “hot” enough that I could hold my hand around the base for few seconds, and just low enough temperature that I didn’t have to let go of it immediately.  I was running RedLine MT-90 in both the tranny and t-case in my '85.
The tranny shifter was almost that hot.
If you don’t know the condition of your gear oil in your transmission and t-case, change them.  In extreme cold winters, I’d be using full synthetic… Mobil 1 or RedLine.
Gnarls.
« Last Edit: Dec 04, 2017, 02:34:01 AM by Gnarly4X »
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #5 on: Dec 03, 2017, 05:25:46 PM »
I cooled down the heat of the tranny by putting a heat shield (upside down U using home heating exhaust ducting) around the exhaust down pipe until it got to the cat.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Last post Nov 20, 2005, 05:19:12 PM
by Marlin
Last post Jul 27, 2011, 08:35:49 PM
by Tyler+Ashleys4runner
Last post Nov 16, 2011, 01:34:45 PM
by tom85
Last post Apr 07, 2015, 09:09:07 PM
by Poorboyz
Last post Apr 29, 2015, 03:37:10 AM
by rottedv
