Author Topic: 22R Hybrid valve clearance issues  (Read 2593 times)
MrFatEggs
  • Member since Apr '17
« on: Apr 02, 2017, 07:52:17 PM »
Hi, I am in the process of building a 22r hybrid motor, but I'm having trouble with the valves. I did the clay test and the intake valve is just barely kissing the piston. What can I do about that other than stacking headgaskets?
This is the motor:
20r head from 1980 corona
Delta 272 cam- 433 lift
Rocker arm assembly from 22r
22r valves and springs
1983 22r block
Block bored 40 over
40 over pistons
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
Re: 22R Hybrid valve clearance issues
« Reply #1 on: Apr 02, 2017, 08:02:27 PM »
you need to clearance the pistons
MrFatEggs [OP]
« Reply #2 on: Apr 03, 2017, 10:34:26 AM »
How do I go about doing that?
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
« Reply #3 on: Apr 03, 2017, 12:15:21 PM »
Machine shop.  Shouldn't cost too much if you can find someone to do it.  I had a buddy that use an angle grinder but that's pretty sketchy :).
You could just run a stock cam and not have to worry about it.  Gnarls on here ran some pulls on a bunch of cam profiles on some kind of desktop dyno and the stock cam profile isn't exactly bad unless you are going with a really nasty cam.  The stock cam makes more bottom end, has a really broad torque sweet spot and wraps out pretty well too. I am running it in a 20r/22r hybrid and after some tuning with an adjustable cam gear and getting the carb freed up and dialed in I am fairly impressed with the whole setup over a stock 22r.  It's not a 3RZ but it's getting there.  I can tell you if this engine was in a smaller, lighter pickup or a car it would absolutely rip!
Here this thread has a whole bunch of spreadsheets in it that Gnarly posted up.  I think some of the later ones even had the 20r data in the hypotheticals:  http://board.marlincrawler.com/index.php?topic=100575.0
« Last Edit: Apr 03, 2017, 12:28:33 PM by H8PVMNT »
MrFatEggs [OP]
« Reply #4 on: Apr 05, 2017, 03:06:13 PM »
I went ahead and used a grinding wheel on a dremel and took about the same amount of material off each side of the piston to keep it balanced, then repeated with the other 3. Thanks for the help!
  • Male Posts: 3,554
« Reply #5 on: Apr 06, 2017, 03:43:32 AM »
I didn't really consider that one a good suggestion but I guess there's no reason it can't work.  The guy I knew who did it took a power washer to the pistons and deck after words to clean the dust off :).  Anyway it worked for him so I would guess it will work for you.  Good luck man you got balls!
Last post Oct 14, 2006, 11:40:08 PM
by CaliZuki
Last post Feb 08, 2007, 10:04:20 AM
by Bloomcounty
Last post Nov 01, 2010, 09:13:59 AM
by ninja turtle
Last post Jan 25, 2011, 01:09:04 PM
by jrock
Last post Jan 06, 2020, 07:57:16 AM
by mwhite49
