another 63" spring question
Started by Skinny_Pedal, April 04, 2005, 10:11:47 PM
Skinny_Pedal
can u run a johnny joint with the double shackles setup on the chevy springs? if u do single, how do u go about doing it. i dont need a bunch of lift, just want flex
Im an OG
Put a 1 ton bail of hay in the back and the rear will flex great.  Otherwise put something else in there for springs. ;)
DontStall Rockcrwl
inboarding those things does help quite a bit. inboarded with johnny joints and a 3 pack with no overload is the way to go.. just make sure you have some weight back there  :beerchug:
You have all gotta be jealous how close i live to the 'Con
IronClad
toss in some  ford f150 springs or somthing else..  chevies  get to much hype and dont preform  as well as  they are said to.
Annihilation  Fabrication
Do you need a Hammer?
Jack8542
Put the chevys with no overloads and buggy springs.  I used double shackles before my buggies and i gained at least 5 inches of drop.  If you inbord the springs as well as do a buggy you could have enough travel to never lift a tire on the trail.   :turtle:  :usa:
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
RHG
sorry about the newb question but what is a buggy spring? Im saving some $$$ to do a budget SAS and want to put rears in front and chevys in rear. Any sugestions on how to pack the leafs? Any ideas are greatly appreciated. Thanx
mr4x42u
If your going to run a buggy leaf or double shackle then don't bother with the 63' spring,,I think its pretty pointless to put a long spring like the chevy in when the double shackles or buggy leaf will do most of the work..If your going to run that set up just use a stock spring and buggy leaf or duel shackles.
CTENG in KS
Quote from: rocks hurt good on May 01, 2005, 10:54:18 PM
http://www.pirate4x4.com/forum/showthread.php?t=152259&highlight=buggy+leaves
See here for pictures of buggy leaf setup.
RHG
oh sweet, i know what that is just havnt heard it called that. A buddy of mine run that on his 85. isnt that hard to control axle wrap? I think he runs a re-packed chevy for the main and a cut down chevy for the "buggy spring"
James's chevy springs and buggy springs work pretty good together.  He doesn't get that much axle wrap.  the only bad thing baout them is maybe unloading going down a hill and the noise it makes when they hit the frame.  But that can be fixed by putting a rubber mount inbetween the frame and buggy.
RHG
sounds like a good budget setup for some bad ass articulation. If I were to pull some 63"ers out of say a mid 80's chevy I would obviosly take out the overloads is that bout it? I can find some springs dirt cheap at the pick n pull down the road. thanx for the pic CTENG
mr4x42u
You would need them out of a chevy with ifs..mid 80's stright axle chevies had a 53 in springs I think,,wich is still a good length spring for a top leaf..I'm not running an overload,,some do,,some need the extra 1/2 lift they give to sit level,,some needs blocks..Its one of those things that is rig dependant..
UNBREAKABLE
3/4 elliptic
That's how I roll
RHG
yeah...eliptic thats what ive heard them called :hammerhead: i think i am going to just go with chevys at first then when i get a chance ill toss in the buggy spring and see how i like it. ill have to give it some :headscratch:
Yota4life
I DONT like my buggies....If there is no weight in your bed, your probley going to die. No but really the more weight in the bed the better the buggies will be. They give to much axle wrap
RHG
I dont think i should run into those problems. I plan on runing a full size spare 35"-37" along with a couple jerry cans, hi lift, etc. It all adds up.
mr4x42u
my 63 chevies with no buggy leafs and no duel shackles..
I run a j/j shackle mount though..
mr4x42u
