1988 3VZE clutch pedal dropped and will not engage
Started by cowsinblack, October 31, 2016, 10:10:23 PM
cowsinblack
I have a 1988 3VZE. I was driving in a downpour for about an hour today and my clutch pedal began to drop very easily with essentially no tension and engage really close to the floor. Shifting became very difficult quite quickly and I had to force the tranny in 2nd and keep it there till I got home where it sits now. The clutch will not engage at all anymore and the pedal will stay on the floor after I remove my foot from the pedal. The engine has 165k on it. I'm currently looking for documentation of any clutch replacement in its past ownership. Any advice is greatly appreciated. And please go easy on the 3 slow jokes.
Mudder
Check the adjustment rod between the clutch master and the clutch pedal  if it came off then the pedal could've moved or it could be extremely out of adjustment .
cowsinblack
The first photo is with the clutch pedal disengaged. This photo is with the pedal touching the floor.
OTO Phil
Check the slave cylinder isn't leaking
Sent from my LG-H830 using Tapatalk
emsvitil
Quote from: excabswap on October 31, 2016, 11:15:58 PM
and the master
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
Quote from: cowsinblack on October 31, 2016, 10:10:23 PM
is there fluid in the clutch reservoir?
OVRAROK
from the pics, it looks like the rubber boot for clutch master in the interior is shiny/ wet.
cowsinblack
The rubber boot for the clutch master is very damp.
cowsinblack
I bled the clutch lines and fixed the issue. Theres a leak somewhere that I need to locate. Thanks for the suggestions!
emsvitil
You can gain some time by clutch less shifting.
Save the clutch for 1st gear dead stop......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
cowsinblack
Are you joking? I as not aware that it was safe for the tranny to do that. I have shifted without the clutch before but never continuously. Could you explain a bit?
OVRAROK
match the engine speed with the transmission speed and shift it
OVRAROK
after staring at the pics, I'm sure 1 of the problems is the master clutch cylinder. I would swap master cylinder
emsvitil
Start with upshifts.
Don't force it.
This may help:
https://www.youtube.com/watch?v=jLw0hAtOik4
Knowing how has saved my butt many times (the starter override switch so you can start in 1st gear is useful too).       I'll practice every once in awhile.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
gnob
Are you guys freakin' serious?
This guy has a bad master, you can see in the pics.
His white "hose" is the clutch cancel switch.
Guy.
Replace the master cylinder.
Either massage that bracket so it works or just wire the two wires together and move on.
hold this. . .
