I can tell you from experience of wheeling our area. You can never put too much paint on a front axle. All the shrubbery and dirt we run over takes them to bare metal quick.
Just a suggestion but consider the brush on paint. I have experienced far better results, and You can lay it on thick. Plus there is no overspray.
Think I could use the brush on over what I've already sprayed?
Are you planning on attending the round up. Would like to see this build in person
After the better part of a year searching and searching.... I present to you.... FJ80 HP Elocker third 5.29FJ Cruiser Std Elocker third 5.29
looks like this build gunna turn out pretty nice... keep up the good work
What is the wiring plan that your going to do for the elockers? If your going to wire it up your self and use the built in limiting switches and use relays I have a really good diagram that I found awhile back I could get you. Sent from my iPhone using Tapatalk
Started by mitchell « 1 2 » Project Research and Build-Ups
Started by Jud « 1 2 ... 23 24 » Project Research and Build-Ups
Started by kvn85 « 1 2 » Project Research and Build-Ups
Started by SoUtHTeXaSyOtAs Project Research and Build-Ups
Started by Jason E. « 1 2 » Project Research and Build-Ups
