Filter has not been replaced, pump is working fine, carb was adjusted, has great spark, solenoid seems to be working fine, will be checking the dist. gear soon, I havent found a webber that is street legal yet, but thats what i would like to do. Im in calif. and i drive it a lot.
Gnarly4X, the stumble feels like all of those. Like lack of fuel, Like a missfire and sputtering at cruise, like off idle miss, sometimes sputters off idle like a lack of fuel. Im pretty confident that the rebuild was done well. I have checked for vacuum leaks, fixed the one, no improvement. I replaced the filter, no improvement. I will have to check all the spark plugs and wires again. Weber carb kit from LCE, i have an 87, and that one is for the 81-84.
Sorry its been a while, ive been driving our xterra. I will check it out this weekend and get back to you. Is there anything with the weber as far as all the electrical that i would need to modify or switch in order to pass smog?
Started by GRSJetsFan Toyota Pickup/4Runner Tech 1979-95
Started by 85toycrawler Toyota Pickup/4Runner Tech 1979-95
Started by Osage1978 Engine
