Author Topic: R150F tranny  (Read 1267 times)
RobertSDriver
  • Turtle Points: -13
  • Member since Aug '16
R150F tranny
« on: Aug 06, 2016, 12:17:36 PM »
   I have a 1993 Toyota 4x4 pickup with 3.0 V6 and a R150F tranny. I am trying to locate the 33311 input shaft for replacement. Does anyone have a source or even the Toyota part number so that I can search further? Robert
I own a 1990 T10 4x4 w/22RE and W56, a 1993 T10 4x4 w/3vze and R150F, a 1994 T10 4x4 w/22RE and W56, all on 32x11.50 Falkens. I also own a 2010 Camry LE, w/2.5 and 6 speed auto.
BoG-ToY
  • Turtle Points: 594
  • Male Posts: 2,122
  • Member since Dec '05
Re: R150F tranny
« Reply #1 on: Aug 07, 2016, 08:57:38 AM »
What's weird is I would think anyone doing a 3.4 swap would need to change out that input? Leaving the correct one to get to you.
RobertSDriver [OP]
Re: R150F tranny
« Reply #2 on: Aug 10, 2016, 03:50:59 PM »
Know anyone out there that's done a swap?
BoG-ToY
  • Male Posts: 2,122
Re: R150F tranny
« Reply #3 on: Aug 10, 2016, 09:24:43 PM »
I do not. I was/am slightly in the same boat. I wanted to TDI swap a 4runner. preferably a 97. I wanted a v6 for towing capacity. I have a r151 bellhousing, but in order to used it I would need an early v6 input shaft. I think I will probably end up doing an automatic if I ever get around to the swap. Right now I have an 85 toyota/tdi/samurai body frame combo. axles trans and tcase are all yota, frame steering box body are samurai and a 1.9 manual pumped TDI  about 80% complete at this moment.
RobertSDriver [OP]
Re: R150F tranny
« Reply #4 on: Aug 13, 2016, 06:22:14 AM »
Thanks for responding, I guess I'm going to have to pull the shaft and weld it up and turn it back down to specs. It's a lot of extra work but without a part number or a source for a new or good used one my options are limited. Do you know if the shaft will come out the front if you pull the bearing? That would save a lot extra work tearing down the gearbox.
Last post Sep 04, 2003, 02:20:29 PM
by obscurotron
Last post Sep 14, 2010, 03:01:57 PM
by superyota
Last post Jul 01, 2013, 11:06:13 AM
by johnny916
Last post Jul 01, 2013, 06:25:26 AM
by notcrawlingyet
Last post Sep 26, 2013, 10:12:53 PM
by THEMAN
