1985 Toyota SR5 4x4 with 22RE wiring and TPS question
Started by Hickory Nut, March 13, 2016, 04:06:30 PM
Hickory Nut
Okay all you 22RE gurus. Today while messing around with my truck I cracked the Air Intake boot on my 22re. While the intake hose was off I noticed a 4 prong plug for the harness electrical taped up. It was spliced to a three wire plug going into the TPS. The makeshift splice was literally electrical taped together. I decided to cut off the 4 prong plug that was on the original harness and just use the 3 prong that was plugged into the TPS.
The 4 prong plug has a brown, black, blue, and white wire. The 3 prong plug has a red, black, and blue wire. White was connected to red, black to black and blue to blue and I heat shrinked the brown wire.
Just for the heck of it I tried to crank it but it started up and died almost instantly. Do you guys think me fixing the makeshift splice would cause this or the broken air intake boot? I will order a new boot because I broke the old one. I used quality splices and heat shrink to fix the rigged wiring.
I assume that either the engine or tps was changed at one time or another but I would think the ecu would have had to be changed as well. What are your thoughts? Any Ideas?
Thanks
OVRAROK
Quote from: bwalker on March 13, 2016, 04:06:30 PM
Thanks
changed to boot, if you did not change anything, as far as wires connected to one another
Hickory Nut
I got the new intake boot and tightened all the intake clamps. Runs Like a top now.
