0 Members and 9 Guests are viewing this topic.
The input of your t-case is from a t-case that came behind a 4 speed transmission He says that because if you look at the splines they are flat across the top. Those only came behind a 4 speed transmission. Your adapter is a downey for either a t350 or 700r4. Won't know exactly which until you clean it and give us a part number. They did make one that worked with both a t350 and 700r but had to use a 2wd trans and a special shaft that they supplied if I remember correctly.Sent from my iPhone using Tapatalk
The input of your t-case is from a t-case that came behind a 4 speed transmission Sent from my iPhone using Tapatalk
Started by yota-tota Project Research and Build-Ups
Started by superyota Parts Wanted
Started by werty Parts Wanted
Started by red450r Parts For Sale
Started by vaj70cruiser Parts Wanted
