alternator problems
Started by GoldnGateYota, February 11, 2016, 03:50:16 PM
GoldnGateYota
hey everyone, i have a 1980 toyota pickup that i just finished building, or so i thought. was running great and charging the battery perfectly then one day it stopped charging. so i took the battery out to get checked at my local napa and it was perfect while i was there i got a new alternator. installed the new alternator and when i connected the negative on the battery the wires on the alternator started smoking.. any help is much appreciated
GoldnGateYota
so a few things i left out there is a small black wire hanging around which i cannot figure out where it would go. and also the new alternator fits the original plug which is the green one and the one i took out needed this black to white plugs to fit!
GoldnGateYota
the green plug and the random black wire
OTO Phil
You might have accidentally grounded the positive lead going off the alternator... Check to see if you have any short circuits starting at your alternator, going back to your battery.
GoldnGateYota
thanks for the reply pgragg! I followed the wires all the way threw and everything was fine, nothing grounded. checked all my grounds finally got fed up with the alternator. So i returned it for the same style one that was in it before (1979) plugged it in and everything worked perfect!
OTO Phil
Sorry it didn't work out for ya
jssgbsn
I went through two different alternators from a 'parts' store before deciding to buy a rebiult high output alternator.  Next time I run into a bad alternator on any vehilce im just gonna get it rebuilt by a alternator/started shop.  Cheaper and you know its gonna work correctly.
If I don't ask the stupid question, who will?
85 Runner, 22RE, AEM 'warm intake', TRD Cam, LC Headers, Dual Case, 5.29's, ARB Front Locker, Detroit Rear Locker, 35's, V6 Brakes, ARP Studs, Marlin Arms/Caps/Hy-Steer, Winch, Armor, Can-Back Top....and...
...more Gremlins than Gizmo the Mogwai was responsible for.
OTO Phil
Know of any good shops near Portland?
xhootiehoox
Hey guys quick question I did a motor swap same motor out of a month earlier truck everything works great cent my charge light is on the alternater to a dump yesterday I am thinkin the batter is bad too just change em both and see what happens?
The secret is more beer and better music 🇺🇸
OVRAROK
I would charge battery, then try to put a load on it, with a battery load tester, if battery is good, no reason to swap out
xhootiehoox
Hey just to say real fast I found out the 80s pick ups have two alternater some is a 45amp the other is a 55 I think and it all depends on ur design if it's a 5 wire main or a 6 wire main mine has a 5 wire main in it and I had the altanator for a 6 wire and it did what ur saying so check it out maybe that helps
