3rd gen Ex cab swap!
Started by OTO Phil, January 31, 2016, 10:53:36 PM
OTO Phil
Need help with my excab swap! I'm trying to put the fuel tank in the stock location, but the filler neck is giving me a hard time... Probably because the fill hole on the side of the tank is pretty obstructed by the cab itself..
So I'm trying to figure out the most efficient, cheap, not too complicated fuel tank swap that will fit between my frame rails behind the rear axle.  I've seen some people use a ford f150 gas tank, but what I'm needing is someone with experience doing multiple different tank swaps so that they can tell me which swap was easiest, and cheapest etc...
I know of other swaps already. I've done my HW to figure out what options I have... Just need to find someone that's done a few before.
Thanks
redneckcustoms13
Go to junk yard, grab a tank form an s10 blazer it goes in the rear of the frame.
01 double cab hunting truck
06 tacoma street truck
OTO Phil
Quote from: redneckcustoms13 on February 01, 2016, 05:48:57 PM
What year range? all? What about wiring? Will everything work i.e. fuel gauge, pump etc...
redneckcustoms13
All s10 blazers run the same tank from my experience. They run 55-65 psi fuel pressure. Idk on the gauge, I'd imagine that an ohm meter could answer that question
OTO Phil
Quote from: redneckcustoms13 on February 03, 2016, 10:16:44 AM
If I have to transfer the gauge over, I picked this up..
